Old 11-07-2018, 05:20 PM   #1
SlayZombi
SlayZombi will become famous soon enough
2001 SL
Default Successful ECTS Change!
Man, you guys weren't kidding when you said all of those nylon sensors crack. Mine that I just bought with only 72k miles STILL had a couple cracks with an excessively long one all down the side. Replaced it with an ACDelco brass one from RockAuto along with a new pigtail for replacing the sensor. The temp still hangs around the first tick on the gauge but I'll just chalk that up to lower outside temps and fresh DEXcool coolant.
Add to SlayZombi's Reputation
Rate the quality of this post and help SlayZombi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlayZombi is offline   Reply With Quote
Old 11-07-2018, 05:43 PM   #2
Default Re: Successful ECTS Change!
Connect a reader to display coolant temps to be sure. The faulty coolant sensor often causes an overheating condition - during warm weather, coolant temps will rise and when the faulty coolant sensor can't detect rising temps, overheating occurs as the pcm never turns on the cooling fan. The temperature gauge displays incorrect temps since the coolant sensor failed so gauge readings are displaying incorrect temps. Hotter coolant melts the rubber seals on t-stats so coolant temps run cooler after the replacement coolant sensor sends correct signals. A reader is one way to see actual coolant temps since the pcm drives the temperature gauge from the sensor. If you see less than 185F after a full engine warm-up, replace the t-stat. Another way to tell if the t-stat failed is to select hot from your heater. It should be very hot. Many find out in the middle of winter of t-stat failure when their heaters are luke warm due to a faulty t-stat caused by the coolant sensor failure.
Old 11-07-2018, 09:28 PM   #3
trottida
trottida's Avatar
How did you do your wire connections? Should be soldered and shrink tubed to ensure a good signal to the PCM. Crimp connectors are a point of failure.
What condition is your thermostat in? A leaky thermostat will also cause low operating temperatures. Here's how to test it ...
Here's how to check if your thermostat is leaking. Starting with a cold engine, start the engine and put your hand on the the lower radiator hose just after the thermostat. If that hose gets warm after a minute or so then your thermostat is leaking. The thermostat should stay closed until the coolant temperature reaches 188-195 degrees Celsius. It takes several minute of run time to reach this temperature.
Let us know what model year and if you're running a DOHC or SOHC. Put your model year and model into your profile and/or signature so it shows in every post.
Here are links to your images that aren't showing up.
https://plus.google.com/photos/10561...Kbm7aT_q5Hd0gE
2001 SL1 MT (433,500 km @ 06/2019)
1999 SL2 MT (277,300 km @ 06/2019)
2011 Suburban LT (128,250 km @ 06/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 11-07-2018, 09:29 PM   #4
RobertGary1
Now you need to change the thermostat. Then your temp will be correct.
-Robert
Old 11-09-2018, 11:28 PM   #5
SlayZombi
2001 SL
-Robert
Will be working on that soon. Already have the part but I will change it whenever I have time.
Old 11-09-2018, 11:31 PM   #6
SlayZombi
2001 SL
[QUOTE=trottida;2285711]How did you do your wire connections? Should be soldered and shrink tubed to ensure a good signal to the PCM. Crimp connectors are a point of failure.
I did solder on both wires and individually electrical taped them all the way down and finished by electrical taping both together and zip-tying to another set of wires next to the airbox area.
Successful pully change thanks to richpin-newbees look! mac99sl2 S-Series Tech 5 01-13-2008 07:26 PM
ECTS Change Question DonP S-Series Tech 2 08-25-2006 08:14 PM
ECTS change.....man that was easy. dbruce S-Series Tech 3 08-05-2006 05:50 PM
Can i change the ECTS myself? arunsam3000 S-Series General 10 12-18-2005 10:15 AM
Change ECTS on SW2 with no symptoms? joshjani S-Series Tech 5 03-25-2005 06:43 PM
