Old 10-29-2018, 03:27 PM   #1
djones09
djones09 is on a distinguished road
Default 08 Aura Lights won't work :(
I know I know, posting about simple headlights? Ive tried everything, but I can't get my headlights to work. When I unlocked my car the headlights come on just fine, but when I start the car they don't work at all no matter if the lights are in auto or not. The brights work just fine, it's just the low beams. Ever happen to anyone, or anyone know how to fix? I've tried new bulbs, and even fuses, but that didnt work.
Add to djones09's Reputation
Rate the quality of this post and help djones09 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djones09 is offline   Reply With Quote
Old 10-29-2018, 05:25 PM   #2
explorerbigjon
explorerbigjon will become famous soon enough
2008 AURA XE
Default Re: 08 Aura Lights won't work :(
The unlock function turns on the high beams anyways, it never turns on the low beams - that part is irrelevant.
Your low beams function turn on several different ways. They turn on as daytime running lights while the car is in gear during the day light. Have you seen them work during the day time?
Have you checked the headlight relay? Swap with a similar relay such as the DRL or Horn relay.
If switching relays does not make it function, then I would check the bulb sockets for melting, scorching or arcing and check for any other kind of damage to the wire harnesses of the headlights. I would replace the headlight pigtails if there is any evidence of those things.
2008 Saturn Aura XE 3.5-Sport tuning T10 wheels-Dynomax bullet/Borla ProXS-eBay intake-Pioneer Premier 12 shallow mount/Kicker CXA600.1
Upgrades coming!
Add to explorerbigjon's Reputation
Rate the quality of this post and help explorerbigjon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
explorerbigjon is offline   Reply With Quote
Old 10-29-2018, 08:34 PM   #3
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
Here is a diagrams of the under hood fusebox.
Check that low beam headlight fuses #7 and #9 are not burnt out.
If they are OK
Swap the headlight relays #35 (High Beam) and #38 (Low Beam)
If Low Beams start working and the high beams stop working, replace relay #35 with a new one.
If none of the above solves the problem, you have two burnt bulbs, faulty headlight connectors or some other wiring issue.
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97 Saturn sl2 no tail lights or dash lights and rear defrost not work Crystal42888 S-Series General 2 09-25-2016 01:19 PM
No dash/running lights, but DTR, Hi/Low, brake/signal lights work??? Haybale S-Series General 1 08-10-2013 12:49 AM
I wonder if this would work in the Aura golftango Aura General 2 10-11-2012 01:23 AM
Fan, BL, Fog lights, ac all don't work bsdeck Support Forum for Canadian Saturn Owners 4 12-06-2011 11:48 AM
Bad body work done to my Aura lovegunxr Aura General 5 07-23-2007 09:53 AM
