Old 10-23-2018, 11:18 PM   #1
danielcg
danielcg is on a distinguished road
Wrench Melted yellow L wire on alternator
Does anyone know what would cause the L (yellow) wire from my alternator to melt? It was the only wire present on the plug that connects to the alt. The car is a 2002 Saturn SC2 with aftermarket audio installed, which definitely could have overloaded the alternator. But I was just wondering if something else could be wrong because I thought the current for accessories would flow through the beefier cable rather the tiny yellow wire. It may be worth mentioning that even though my alternator is not charging the battery, the charging system dashboard light does not come on after the bulb test. What is that wire even used for?
Add to danielcg's Reputation
Rate the quality of this post and help danielcg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
danielcg is offline   Reply With Quote
Old 10-24-2018, 12:01 AM   #2
billr
Default Re: Melted yellow L wire on alternator
Well, one function of that "L" wire is to turn on the dash light when the alternator output is less than battery voltage. It can't do that if it is burned out...
It sounds like the aftermarket stuff was installed incorrectly.
Add to billr's Reputation
Old 10-24-2018, 07:53 AM   #3
The alternator is controlled differently in the gen3 than it is in the older generations. The BCM turns on the light.
looking at the diagram it is likely that the "L" wire has been shorted to ground. The alternator may also be defective and the cause of the failure.
Old 10-24-2018, 03:02 PM   #4
billr
Yep, my mistake. I should have known it was risky commenting on a gen3 when I don't have schematics that go up into those years.
Ignition Switch Pluggin Wire Melted dcole2525 S-Series Tech 12 10-29-2012 01:44 AM
Yellow Gunk on Alternator XRL Vue Tech 3 03-14-2010 11:04 PM
? On Melted Wire in Harness Ragucci05 L-Series General 2 02-08-2007 08:29 PM
FS: Yellow wire loom Green98SC2 Classifieds 0 12-19-2003 11:12 AM
FS: Yellow wire loom Green98SC2 Classifieds 19 12-11-2003 02:16 PM
