Old 10-23-2018, 12:03 PM   #1
Walkop
Walkop is on a distinguished road
Walkop's Avatar
Question What gaskets do I need for timing belt replacement? 2006 Vue 3.5l V6
Searched everywhere on here, no results. I'm using RockAuto. What gaskets do I need to order for the timing cover and related parts when replacing the timing belt? I'm doing the valve adjustment, water pump and plugs, so I already have the intake plenum gasket set and valve cover gasket set in the cart. No idea what I need for the timing belt.
Any help asap would be appreciated!
Also, what tools do everyone use to measure valve lash? Would a spark plug feeler gauge work, or is there a dedicated tool?
2002 SL2 A/T "Pluto" 250,000KM
2006 Vue V6 AWD A/T "Benji" 150,000KM
Walkop is offline   Reply With Quote
Old 10-23-2018, 01:09 PM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: What gaskets do I need for timing belt replacement? 2006 Vue 3.5l V6
...THE TIMING COVERS HAVE RUBBER GASKETS ON THEM, UNLESS THEY HAVE DETERIORATED ,YOU'LL BE FINE, GM/HONDA IS THE ONLY PLACE THAT I'VE SEEN THAT HAS LISTINGS FOR NEW COVERS, NOT SURE YOU CAN JUST GET THE GASKETS, OTHERS WILL CHIME IN, HOPE THAT HELPS, DC
Old 10-23-2018, 04:16 PM   #3
philsplace
philsplace is on a distinguished road
I recently replaced my belt and water pump. the belt covers already have gaskets built in and usually don't need to be replaced.
philsplace is offline   Reply With Quote
Old 10-23-2018, 06:34 PM   #4
Walkop
Walkop's Avatar
Good to know. I'll keep that in mind if I can't find gaskets or they're really expensive (still don't know what ones are needed, though...).
Any thoughts on tools to measure valve lash?
Old 10-24-2018, 07:57 PM   #5
atikovi
Angled feeler gauges.
2006 vue 3.5 with 78k miles, time for timing belt?? d97gt Vue Tech 7 12-13-2015 02:29 PM
Thougts on Timing Belt Replacement 2006 Vue 3.5 IT_Architect Vue General 14 12-03-2015 07:10 PM
2006 Saturn Vue timing belt mark position af0603 General Saturn Discussion 2 05-05-2012 03:00 PM
timing belt replacement marathoner Vue Tech 29 09-28-2011 10:17 PM
Timing belt replacement the hankster L-Series Tech 5 07-27-2010 03:37 PM
