Old 10-23-2018, 08:46 AM   #1
SLfun
SLfun will become famous soon enough
2006 ION Red Line
Default My 98 SL1 DOHC swap eats wheel bearings
In the 10k km since the drive train swap, my Saturn has gone through 2 sets of front wheel bearings.
Now they are dead yet again.
Last time I replaced the bearing/hub together.
Iv'e been reading about 'bearing arching', and it is something I'd like to rule out.
Where should I ground the chassis to make sure I have my electrical bases covered??
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLfun is offline   Reply With Quote
Old 10-23-2018, 12:37 PM   #2
Default Re: My 98 SL1 DOHC swap eats wheel bearings
What do you mean by 'drive train swap'?
Old 10-23-2018, 12:47 PM   #3
trottida
trottida's Avatar
He swapped out the SOHC for a DOHC engine. Hence SL1 DOHC in the title and the notation in his signature. However, there's no relativity to the question asked.
2001 SL1 MT (433,500 km @ 06/2019)
1999 SL2 MT (277,300 km @ 06/2019)
2011 Suburban LT (128,250 km @ 06/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-23-2018, 12:58 PM   #4
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
What are you torquing the axle nut to?
How are you installing the bearings?
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 10-23-2018, 01:23 PM   #5
billr
Bearing arcing, huh? That's really grasping at straws!
Get the knuckle bores checked at a machine-shop for size and roundness. Are the bearings being pressed/pulled in properly? If there is any chance the beloved BFH was ever used for bearing R&R the knuckles are suspect.
PS: How long (miles) are the bearings lasting?
Add to billr's Reputation
Old 10-23-2018, 03:12 PM   #6
SLfun
2006 ION Red Line
So the current set of wheel bearings lasted around 5000 km.
All these wheel bearing failures started after I pulled the SOHC Automatic for a manual DOHC drivetrain. So there is a chance that the 2 are related?
I found this interesting quote from an automotive engineer:
"In fact, I've seen studies by all world's largest bearing manufacturers, and everyone points to bad grounds as right around the third most-common reason for automotive/light truck wheel bearing failure. The first is installer error, of course. The second is accident/driver inflicted damage, and the third is bad grounds."
So I have ordered re manufactured steering knuckles with new bearings already pressed in. At the same time I will replace the LCR's and tie rod ends. Then get an alignment done.
And of course, add more grounds.
I want to cover all my bases so I don't have to do this again.
If there is anything else anyone else can think of, lemme know!
SL1-2.
Old 10-23-2018, 03:17 PM   #7
SLfun
2006 ION Red Line
145 lbs on the axle nut.
The bearings were installed with a press.
SL1-2.
Old 10-23-2018, 05:06 PM   #8
trottida
trottida's Avatar
It's also recommended to use a new spindle nut and washer, as well torque with wheels off the ground and rotating the wheel a few times while torquing.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-23-2018, 05:17 PM   #9
I see now. In addition to incorrect bearing replacement procedures, are there any dimensional differences in the drive train (distances between xmission to wheel hubs) that might create premature wheel bearing wear?
Old 10-23-2018, 06:24 PM   #10
trottida
trottida's Avatar
DOHC and SOHC (engine/trans) use the same axles, spindle, tie rods, and LCA's. They are interchangeable.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-23-2018, 07:10 PM   #11
Waiex191
Waiex191's Avatar
I have heard of bearing arcing on electric motors connected to a drive. Some of those motors, like the ones I bought at my job, have grounding brushes across them. I can't see this as an issue on a Saturn.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-23-2018, 08:10 PM   #12
The wheel bearing failures from electrical arcing can be detected with an AM radio the has analog tuning so you can tuen off of a station and listen for a hissing that changes with speed and wheel load. It is incredibly rare in Saturns.
Usual rapid failure in these cars with the usual replacements is improper bearing preloading. The new nut, washer, and torquing while wheel is rotating and terminating torquing if bearing binds is how it should be done,
Old 10-28-2018, 04:36 PM   #13
SLfun
2006 ION Red Line
Thanks everyone.
So I did the easiest part of the job by installing a ground strap, because it can't hurt anything!
Now I'm just waiting for parts. Can't wait to be able to hear the motor again!
And the radio, and the person talking beside me
SL1-2.
Noise from rear wheel. Wheel bearings going? Rochester S-Series General 7 05-23-2017 12:49 AM
Connecting Rod Bearings 2002 SL2 1.9 DOHC two_sl2s S-Series Tech 3 09-17-2015 06:34 PM
Wheel bearings SaturnIONSLVUE Ion Tech 4 08-30-2012 03:55 PM
Front wheel bearings: Ball or Needle bearings ?? Luke S-Series Tech 12 03-26-2011 08:25 PM
WTB: 96 SL2 DOHC Main Shaft Bearings kickarse Classifieds 1 04-21-2005 12:24 PM
