Old 10-22-2018, 09:34 PM   #1
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
Default code 51 rear axle fail (MOTOR FREE SPINS)
ABS AND BRAKE LIGHT ON ? is this the abs motor issue?
Packard is offline   Reply With Quote
Old 10-23-2018, 12:14 AM   #2
billr
Default Re: code 51 rear axle fail (MOTOR FREE SPINS)
What??? There is no "rear axle" on S-series (just struts and links on each side) and my info shows that 51 is for a "PCM memory failure".
Are you saying that the 4-cylinder engine revs up but the car doesn't move in any gear? Check the axle shafts (driving the front wheels), check the bell-housing for severe trans fluid leakage. Is this a manual trans or auto?
Old 10-23-2018, 12:33 AM   #3
Attached AllData's info. The one that includes 47 & 48 is more of an update/TSB sort of thing while the singular 51 is the full diagnostic info.
Old 10-23-2018, 01:08 PM   #4
billr
Hmm, interesting... I checked about 10 other code listings and they all come up with 51 being a PCM memory fault. Is there a chance Alldata is wrong?
Old 10-23-2018, 01:40 PM   #5
He's trying to figure out how to fix his ABS and thinks making a new thread with less and less info for every new question is the right way to go about it
ABS codes are hard enough to read in the first place that most places online don't even give the full code list for the ABS module. Even AllData doesn't give a dedicated section to ABS codes, you have to pick the code number and then say what system is giving that code.
Old 10-23-2018, 02:24 PM   #6
billr
Are you saying there is a separate list of codes for ABS, similar to the separate list for a TAAT? That makes sense, I just wasn't catching on.
I'm still wondering how the OP knows the motor for the rear ABS circuit "spins free", or even what that means. Is the ABS opened up now? I would expect a motor armature to spin (relatively) free in most cases, that seems normal. Or is the OP powering up the ABS with ports blocked and trying to see if it builds/modulates pressure in some manner?
Regardless, I should bow-out. I have no use for or interest in ABS. I got sucked into this thread because I thought it was about the engine/trans/axles!
Old 10-24-2018, 01:33 AM   #7
Packard
1995
Today I decided to just rip it out .cause last I did some digging on google and most ppl with this issue turn out to be abs . So I went and got it out today . Going to bleed tommorow
THE MIDDLE GEAR NUT WAS ABOUT TO FALLL off and it was free spinning just like I thought .
Old 10-24-2018, 01:37 AM   #8
Packard
1995
Old 10-24-2018, 02:14 AM   #9
ABS, Emissions (PCM/CEL), Air Bag & Transmission all have "a" code 51. Alldata doesn't list them for 1st gen by system, just by number so that's 4 totally different 'code 51' that could be looked up separately and each one is technically correct without the info that the OP is working on the ABS system.
ABS code 51 is for low amperage. With computers 'low' includes 0v up to a certain percentage under whatever the correct voltage is (usually 5%, some might go as high as 15%) so a motor that free spins would have 0 voltage and therefore 0 amps.
Old 10-24-2018, 07:35 AM   #10
Packard
1995
Now I know there is a method to bleed them with the harness . I read the the gears have to be counter clockwise but not certain if that means to just let them be sitting the entire way at 100 percent.
SL2 auto trans spins free oldchevytrucker S-Series Tech 3 11-07-2015 02:25 AM
1995 SL2 starter motor spins but does not engage eddacker S-Series Tech 6 02-01-2015 11:57 AM
HELP! Rear axle nut fail (Motor free spins) johnny3336 S-Series General 3 08-09-2007 12:28 PM
ABS code 51, rear axle nut fail (Motor free spins) johnny3336 S-Series Tech 1 02-13-2007 01:55 PM
help!starter motor spins but not engaging engine therapist Miscellaneous Tech 3 11-23-2000 11:45 PM
