Old 10-22-2018, 12:01 PM   #1
tbirddad
tbirddad has a spectacular aura abouttbirddad has a spectacular aura abouttbirddad has a spectacular aura about
Default Weird starting problem with my SL1
So I have a 2000 SL1.
Would not start. When I turn the key all lights come on normal. Battery fine.
Will not start in Park or neutral.
I changed the neutral safety switch on advice from a Saturn forum.
Now, will not start in Park
Will start perfectly fine in neutral.
When running, if I put the car in neutral and turn off the car, and then try to start again, while it remains in neutral, it will not start.
But if I move the shifter to Park and back to neutral, starts up just fine.
Very confused.
Add to tbirddad's Reputation
Rate the quality of this post and help tbirddad reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tbirddad is offline   Reply With Quote
Old 10-22-2018, 06:04 PM   #2
Default Re: Weird starting problem with my SL1
You may have two or three separate issues so troubleshooting one may solve all issues or at least eliminate one problem before moving on to the second one. Power and starting circuit are the two issues that comes to mind. A third issue may be a worn out starter. Power should be checked first. Without power, starting circuits cannot work to enable a starter to run. Be sure all testing is done in Park position and parking brake engaged.
How old is the battery? Are both battery cables clean, free of corrosion, not loose on the battery? Two main grounds are used, chassis and engine block - check them for loose, corroded connections. A quick way to test battery and connections would be shorting the two starter terminals, the outer large terminal with battery cable to the small terminal with a single purple wire. Leave ignition OFF. Shorting these two terminals on the starter should result in starter operation, turning over the engine. Either the battery/cables are fine and power the starter or not. Try this several times as you're bypassing the entire starting circuit to get the starter to run. Several consistent operation of this starter verifies battery, cables, their connections and starter. If the starter doesn't operate each time perfectly, battery testing should be performed at any store selling car batteries. They should have free battery testing to determine if a battery is on its last legs, needs charging or in perfect condition. Finding a perfect battery test then points to a worn out starter (if original). The starting circuit test requires a multimeter.
When turning the ignition switch to the START position, the ign switch sends 12v to the small terminal on the starter that powers the solenoid. Measuring voltage on the small terminal should have the meter show battery voltage as long as the ign switch is held in the START position. Beware that starter operation is expected every time when starting. Disconnecting the small gauge purple wire is safer but battery negative should be disconnected first then purple wire to avoid contacting the battery cable connection with tools resulting in battery arcing or grounding battery power to the starter case. After disconnecting battery negative then the small wire to the starter, reconnect battery negative to perform the starting circuit test. 12v is on the small purple wire only when ign is in START position.
Old 10-22-2018, 08:36 PM   #3
Cheyne
2000 SL2
Did you get the switch adjusted properly so that you have continuity when Drive is selected?
Add to Cheyne's Reputation
Old 10-22-2018, 10:08 PM   #4
tbirddad
I just replaced the old NSS with a new one.
Perhaps you are on to the problem.
Where is there information on how to properly put in the new switch?
Old 10-22-2018, 10:26 PM   #5
Cheyne
2000 SL2
Video on adjusting:
https://www.youtube.com/watch?v=vjwxw8A08Sw
Old 10-23-2018, 01:39 PM   #6
tbirddad
Thank you Cheyne.
That makes sense.
Iíll let you know what the result is.
I appreciate your response!
Old 10-31-2018, 11:03 AM   #7
tbirddad
So I hooked up the multimeter as directed and adjusted it.
Super easy to do.
I didnít have to remove anything but I did disconnect the battery.
Works fine!
Thanks for the help!
02 SL1 Weird Starting joelawrence S-Series Tech 9 01-17-2012 02:38 PM
2000 Saturn Sedan - weird starting problem Traci1211 S-Series Tech 7 03-23-2011 09:26 PM
Weird starting issue entry1wound S-Series General 1 12-03-2010 06:03 PM
Weird Starting Problem fullhart S-Series Tech 4 01-31-2007 02:53 PM
'98 SL2 Weird Starting Problem moonak98SL2 S-Series General 3 10-23-2005 10:16 AM
