Old 10-21-2018, 09:31 PM   #1
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
Default Bosch Wiper Motor much louder than Stock unit
We got two 2000 S Series SL2s. One has a labeled Saturn Wiper Motor, the other a Bosch but the Bosch one was made in Aug of 2000 so I suspect it was in the car from new. The issue is the difference in noise. The Bosch one is much louder in the car than the Saturn one. An acquaintance who has owned six S series told me most of them were loud and not to worry about it. Should I be concerned ? It has worked fine for 5 years ? or is it on it's last legs ?
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 10-21-2018, 11:37 PM   #2
Default Re: Bosch Wiper Motor much louder than Stock unit
I can't answer your question directly but can share one story about Bosch dc motors.
I had a Mercury Sable wagon, 3.0L V6 automatic before buying my Saturn L300. The rear wiper was erratic and stopped so I decided to try repairs. Once removed, it was a Bosch wiper motor. It was clean and lubed when the gear case was opened. Other than some corrosion around the exterior shaft, my guess was a possible micro switch or wiring damage. Nothing was found broken and as soon as I applied power to the correct terminals the motor took off as if nothing was wrong. Suspicious of this, I reluctantly put it back and it never failed to run. Possibly never parked the last time it was used or the previous owner forced the wiper out of home position? For whatever reason, simply disassembling and doing almost nothing but move grease around and reassembling it made it run. I didn't repair anything. This rear wiper motor did make a low gear whine but not noisy enough to be distracting in rain. It worked flawlessly. As a rear wiper, it saw less use compared to front wipers so once it went back to normal operation I felt it would last the life of the wagon and if necessary, removed to replace a worn one.
Your choice to replace it or roll the dice and replace it when it fails, if it fails. I had the luxury of removing the rear wiper that wasn't absolutely needed and able to disassemble it to see actual operating hardware before feeling comfortable with it able to run forever.
Old 10-22-2018, 05:52 PM   #3
gveinot
gveinot's Avatar
2000 SL2
2000 SL2
thanks, Bosch is noted to have decent products. At least I know how to take it apart now, next should go half the time.
04 2.2 Vue exhaust rattle....louder than motor RGRG68 Vue General 1 04-12-2018 04:34 PM
Question about Bosch wiper blade sizing stratfink S-Series General 1 11-15-2005 11:14 PM
What does the MP3 playet head unit offer over the stock unit? Blue Goose Vue General 5 11-30-2004 01:18 AM
Bosch wiper blades mr weather Vue General 22 09-02-2004 11:09 AM
LS2 wiper chattering- Bosch? TorontoLS2 Mods and Performance 3 01-07-2003 02:10 AM
