Old 10-21-2018, 03:15 PM   #1
Tired1
Tired1 is on a distinguished road
Question Stuck in reverse
I put car in reverse, and it would not shift into any other gear. I had to leave it on n reverse with the emergency brake engaged. I have researched enough to know that is either 1) the transmission shifter cable, or 2) the transmission shifter solenoid. I am having trouble finding parts, or diagrams of where the parts are on car, and how to do the repairs. Can anyone help?
Thanks.
Tired1 is offline   Reply With Quote
Old 10-21-2018, 08:03 PM   #2
Default Re: Stuck in reverse
Some car info is needed. Are you driving a Lamborghini, Tesla, Land Rover, Jaguar? Engine size? Year, model? Mileage, maintenance done, parts replaced?
Is the battery dead? Tried a battery boost to see if battery or alternator died, preventing shifting out of reverse? If this is a mechanical failure, the shift linkages may be the issue. Without car info, its anyone's guess.
Old 10-21-2018, 11:28 PM   #3
soulsurvives
soulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to all
2002 L-Series 2.2L Sedan
Need more info for sure. Is the shift lever able to move out of reverse? The shifter cable connects to the top of the transmission just to the right of the motor. If the shift lever moves, but doesn't come out of reverse I would start with the cable. If the shift lever won't move out of reverse I would start with the shifter area. Use the little tab to manually bypass the shifter lock.
soulsurvives is offline   Reply With Quote
stuck in 3rd no reverse p0776 p2763 onthebrinc Aura General 4 05-07-2012 06:04 AM
Stall when put in reverse DTC 26 TCC Stuck tomb S-Series Tech 2 12-02-2010 11:24 PM
Car stuck in reverse...HELP!!! peteygnyc L-Series Tech 1 07-10-2010 12:58 PM
2000 LW1 stuck in reverse cadurning L-Series Tech 8 10-30-2008 08:09 PM
What would cause my shifter to get stuck when I reverse? turbobuick33 S-Series Tech 6 06-18-2008 11:29 AM
