Old 10-21-2018, 07:21 AM   #1
BlueArmz
BlueArmz is on a distinguished road
Default Power steering whine
Just asking for a general consensus. I have owned an SL2 for a couple months and noticed that the pump is a little whiny between 1.5-2.5 RPM. I heard this on youtube videos on other SL's. No noise when turning the wheel and steering is fine. Is this just something we Saturn owners get used to and leave alone? Would a JY pull pump do the same thing?
FYI, I've already isolated the noise the the PS pump. New belt, Alternator, idler and tensioner pulley. (No whine when ran without belt)
Thanks.
Add to BlueArmz's Reputation
Rate the quality of this post and help BlueArmz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlueArmz is offline   Reply With Quote
Old 10-21-2018, 04:06 PM   #2
billr
Default Re: Power steering whine
A PS pump whine is not "normal" for an S-series, if that is what you are asking. However, I would ignore it if the PS works OK and there is no fluid leaking. The JY stuff is always a gamble, you may get a better one or you may get a worse one.
I gotta say... it isn't clear to me that you really have isolated this to the PS pump. Eliminating the whine by removing the belt sure indicates that something belt-driven is the cause; but replacement alternators/idlers/etc are sometimes bad them self (especially if you are shopping at a JY!)
Add to billr's Reputation
Old 10-21-2018, 05:04 PM   #3
BlueArmz
Thanks for the reply. The alternator and pulleys are new, not junkyard, so ruling them out. It is definitely coming from the pump. I learned that mine has the EVO sensor on it for the variable speed control. The remans that they sell on rock auto and auto parts stores donít come with the sensor or a place to mount the old one, though they say its variable speed control. Donít have much of a choice except a junkyard one. Iíll prob get a cheap low miles eBay one and try it. I heard that installing a pump without the sensor plugged in makes the steering rack run full assist all the time and makes steering feel bad.
Anyways...
Old 10-21-2018, 05:06 PM   #4
RobertGary1
Only time a whine is expected and normal is if you buy an aftermarket pump. If you stick with junk yard pumps you should never get a whine.
-Robert
Old 10-21-2018, 05:10 PM   #5
BlueArmz
-Robert
Sounds like youíve been through this already.. thanks for the info!
Old 10-22-2018, 12:59 PM   #6
hholbein
1997 SW2
Mine has run a lot quieter since I purged the old dino PS fluid (Dexron III) for synthetic (Transynd). Buying a quart and running 4-5 reservoir refills over a few months might quiet it down, and it will likely be better for the pump, IMHO.
Add to hholbein's Reputation
Old 10-22-2018, 04:56 PM   #7
BlueArmz
My goal is to just find a low mileage pump that has no noise issues. I find that fluids and additives are mostly placebo. A good pump should be quiet using factory spec fluid. Which is my experience with any other car Iíve owned.
Old 10-23-2018, 08:58 AM   #8
Highmile
Highmile's Avatar
I'd just flush the fluid and refill with dexIII.
Highmile
'95 SL1 670k and counting
Add to Highmile's Reputation
Old 10-23-2018, 09:37 AM   #9
BlueArmz
So is most everyone putting ATF in? How would this have an effect in noise levels? Doesnít the owner manual call for just plain old power steering fluid?
Old 10-23-2018, 01:15 PM   #10
billr
I've only had my '94 for 24 yrs. and 220,000 miles. During that time it has never whined, leaked, or had any problems; so I have never even checked the PS fluid. If I ever need to add, I will probably use Dex3. Same for the '95 with 260,000 miles, but I have only had it for 17 years...
Old 10-23-2018, 04:10 PM   #11
BlueArmz
Thatís awesome your getting so many miles out of them. Mine has 167,000 on it and hope to keep it going a long time.
Old 10-23-2018, 05:04 PM   #12
billr
Off-topic, but the clutch on the '94 is original, and we taught all three sons to drive with that car.
Old 10-28-2018, 11:53 AM   #13
BlueArmz
So, I installed a junkyard pump today. Unfortunately this one is louder than the old one. Was really loud until I got the air out but still louder than the old one. . Was a pain of a job so not happy with the outcome. Iím now wondering if I should have just got a new/reman one that doesnít have an EVO sensor. I actually unplugged it and drove around and cannot feel a difference.
What do you guys think? It is just very annoying to have a whine that gets higher pitch as I accelerate.
Old 10-28-2018, 03:56 PM   #14
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
My power steering pump was whining too...
I removed the fluid, and refilled with fresh Dexron III, ran it about 100 miles, then did it again...
Whine is gone, but the fluid is getting nasty again.
I may plumb in a filter on the return line.
https://derale.com/products/filtrati...s/13005-detail
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 10-28-2018, 06:56 PM   #15
BlueArmz
Glad that helped your whine. Mine has all new fluid too, PS fluid though. I guess you never know what you get from the junkyard. The JY pump doesnít seem to have any leaks or anything. Just a little more whiny than the one I took off. I guess the bearings are going bad in both. Hoses donít seem to be leaking. Iím not sure a bad hose would cause noise though.
Old 10-28-2018, 07:09 PM   #16
Cheyne
2000 SL2
You can get a new pump and transfer the EVO to it. The reman units are hit or miss. The OE pump is available but pricey. I replaced mine with the OE that I found a deal on at Amazon at the time.
Add to Cheyne's Reputation
Old 10-28-2018, 07:28 PM   #17
BlueArmz
I saw the ones with EVO on amazon. I couldnít feel any difference when I unhooked my connector as a test, so Iíd prob go with the lower price one. Did you replace yours cause it was noisy or leaking? Mine is noisy when accelerating and reving the engine. Not when turning as to why I think bearings are bad in it. It works, just irritating. Everyone talks about dex 3 being the choice fluid, I might put some in as a last ditch effort.
Old 10-28-2018, 07:43 PM   #18
Cheyne
2000 SL2
Mine was leaking slightly and I questioned the bearing longevity when checking the pulley for play. So I decided to replace the unit rather than just the seal since I don't like to revisit a repair.
The units are not really more since they don't come with the EVO attached. You get the NV7 pump and transfer the EVO from the current pump. Takes a 30mm socket IIRC.
To know if the Dexron III will help, find the spec sheet online for the fluid you used and compare the viscosity. I use Mobil 1 multi-vehicle transmission fluid.
Old 10-28-2018, 07:54 PM   #19
BlueArmz
How do you attach the EVO to the pump if it doesnít have threaded hole to put it in? The NV7s with variable speed have 2 holes, one for high pressure and one for the returns.
Old 10-28-2018, 08:15 PM   #20
Cheyne
2000 SL2
One hole for pressure and one for EVO. The return hose fits a nipple on the reservoir.
RA has a reman AC Delco with the EVO included if you don't want the aggravation of swapping it. I personally wouldn't bother with a reman with reservoir included where they painted it. otherwise I'd swap reservoirs.
IF I went reman I would just get the pump if available and swap EVO and reservoir. I'd do it however where a return was easy and had a long warranty.
I just prefer new to reman if there's a choice.
2008 Vue 3.5L Power Steering Whine poschboy3 2008 Vue 1 02-04-2017 06:12 PM
Power steering whine - EVO at fault? toadson S-Series Tech 16 08-25-2008 02:09 AM
power steering whine maybe ? saturnguy2001 S-Series Tech 5 02-07-2008 04:49 PM
Power Steering whine samh61 Outlook General 3 11-11-2007 06:11 PM
Power Steering Whine Gone exm22psu Aura General 14 06-16-2007 07:17 PM
