Old 10-20-2018, 05:54 PM   #1
cherokee0629
cherokee0629 is on a distinguished road
2000 L-Series 3.0L Wagon
Default 2000 LW2 3.0l Expansion Tank
I am replacing the expansion tank on my 2000 LW2 3.01 wagon. I got an expansion tank off of what I thought was the same wagon but it seems the engine was a 2.2l. Will the expansion tank still work? The one off the 3.0 engine has 3 ports, 2 at the top and one at the bottom. The tank for off of the 2.2l engine has 2 ports one at top one at bottom. I have attached the diagram of both engines.
Add to cherokee0629's Reputation
Rate the quality of this post and help cherokee0629 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cherokee0629 is offline   Reply With Quote
Old 10-20-2018, 08:38 PM   #2
pierrot
pierrot's Avatar
Default Re: 2000 LW2 3.0l Expansion Tank
No.
A careful examination of both diagrams provided is clear enough. The third port on the tank is absolutely necessary for the V6's cooling system, but it's not for that of the 2.2L engine. Find a tank from any L-Series car with a V6 from '00 to '05 whether it's a station wagon or a sedan, they're identical.
Surprisingly, new tanks are still available for your car as of this date (if you must get one)!
317,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 10-20-2018, 09:26 PM   #3
cherokee0629
Thank you. I wanted to make sure that it was necessary.
Old 10-20-2018, 11:26 PM   #4
02 LW300
02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all
02 LW300's Avatar
2002 L-Series 2.2L Sedan
See if the 2.2 tank has the nipple. It just may need to be opened so it can be used. The tanks are same otherwise.
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
Old 10-21-2018, 12:04 AM   #5
pierrot
pierrot's Avatar
If the mounting/bracketing of the tank is identical between for each engine then it would be possible to utilize the the recovery tank for a V6 with a four cylinder engine by merely capping of the third port/nipple. However, it cannot work the other way around. The 2.2L engine's recovery tank has no third port/nipple. In the OEM catalog the part numbers differ for each engine.
(BTW, a radiator suitable for a V6 can be used with a 2.2L engine by capping off the upper nipple at the radiator's driver side tank. That is how my replacement radiator came. The irritating thing about that is the need to replace the cap every two years because they don't last as long as the hoses. Since the OE radiator had no extra port/nipple there was no concern of a leak at that spot. This past Summer I learned that this now would have to be dealt with as a maintenance item. )
Old 10-22-2018, 02:16 PM   #6
cherokee0629
Do you know what the third hose is for on the V6? If I can cap it off I would like to. The sensor on the 3.0 tank fell apart and would like to use the tank for the 2.2.
In the pictures, the one not connected is the one that goes to the radiator.
Old 10-22-2018, 03:11 PM   #7
02 LW300
02 LW300's Avatar
It is part of the system to help get air out of the radiator. You must use it or your cooling system will not work correctly. They used that hose from the radiator to the tank because it is needed.
Old 10-22-2018, 03:13 PM   #8
pierrot
pierrot's Avatar
I'm not familiar with the purpose of the other hose is which connects to the radiator. I would not recommend bypassing that hose as it's clear that the engineers determined it was needed. I am loathe to make changes in the cooling system without knowing how something is supposed to function. Perhaps an examination of FSM could answer the question, but I won't see it until I get home from work.
Old 10-22-2018, 03:40 PM   #9
cherokee0629
Thank you both.
99 SL2 Expansion tank (coolant) leak Colchis S-Series Tech 15 07-05-2014 12:33 AM
Expansion Tank Cap imamacanac S-Series General 3 10-28-2008 10:50 AM
Crap in coolant expansion tank Tom92SCm Vue Tech 13 12-18-2006 07:51 PM
Coolant leak from expansion tank? Norseman S-Series Tech 40 06-30-2005 06:37 AM
coolant expansion tank ? 91SL2 Miscellaneous Tech 3 11-12-2002 06:26 PM
