Old 10-19-2018, 08:49 PM   #1
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
Default No Engine light code 26 plz help?
CODE 26 But my check engine light is off . Does this mean problem is fixed. When I run paperclip code 26 is there but I dont have light . What does this mean? Does this mean it recovered and Im safe to inspections ? If my light is off am I in the clear? Ive already replaced the solenoid for this 26 and it fixed it last time .If my light is off am i ok when I can paper clip a code but then the light is off .
Packard is offline   Reply With Quote
Old 10-19-2018, 10:02 PM   #2
billr
Default Re: No Engine light code 26 plz help?
Unfortunately, that "code 26" is so vague as to be near-useless. It refers to a problem in the PCM outputs, and there are eight of them. The problem could be in one, any or all. The fault could be an open circuit, a shorted circuit, or anything in between. Replacing a single component (like that solenoid) doesn't tell you much about why the 26 is set or fixed. There could be a different cause, or combination of causes, every time you turn the key on.
Is your concern emissions/safety inspection? If the CEL isn't on at time of test, I don't think it will be and issue; "flags" set don't matter.
Old 10-19-2018, 10:20 PM   #3
RobertGary1
For odb 2 an active code with no mil lamp is still an automatic failure. Not sure about odb1
-Robert
Service Engine light but no code Joshtheclockman S-Series Tech 12 10-10-2011 02:47 PM
Engine light, no code. bk63 Vue General 3 09-18-2010 07:28 PM
Need help with engine light code PO430 tripplegs Aura General 10 12-06-2009 06:12 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
check engine light.. no code??? runerx Vue Tech 4 04-17-2006 01:17 AM
