Old 10-19-2018, 08:47 AM   #1
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
Default code 26 stored no check engine light
CODE 26 But my check engine light is off . Does this mean problem is fixed. When I run paperclip code 26 is there but I dont have light . What does this mean? Does this mean it recovered and Im safe to inspections ? If my light is off am I in the clear? Ive already replaced the solenoid for this 26 and it fixed it last time .If my light is off am i ok when I can paper clip a code but then the light is off .
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 10-19-2018, 01:17 PM   #2
Default Re: code 26 stored no check engine light
Old 10-22-2018, 11:53 AM   #3
Saturn Night
With OBD-I, the code will store in the PCM after the error has been corrected. To remove the code from memory, that way you only scan code 12 with the paper clip, simply disconnect the battery for 60 seconds or so.
Code 26 is for Quad Driver Circuit A faults, which there are 4 circuits on a Saturn S-Series, that apply to this code. You have confirmed you repaired the code, and I remember your forum post for the TS you did, last year.
You will be fine for inspections. OBD-I doesn't have a "Ready"/"Not Ready" status for the emissions sensors to indicate if the PCM has recently been cleared of fault codes.
OBD-I merely scans to see if a sensor if it is reading within set parameters or not reading correctly.
Engine light off Stored code should I erase state inspection due Packard S-Series Tech 5 12-10-2016 09:51 AM
code 26 stored no check engine light Packard S-Series General 28 10-30-2016 08:53 AM
Failed Smog Check After Erasing Check Engine Light Code trench619 Ion General 9 05-01-2015 11:58 AM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
check engine light, no code diestrutionomeg S-Series Tech 7 08-03-2004 12:56 AM
