Old 10-19-2018, 02:20 AM   #1
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
Default No check engine paper clip sees code 26
What type of codes are the paper clip ones but I have no check engine . Reads a 26 with paper clip but I have no check engines parts Ive replaced are the egr solenoid and the egr valve . I had trouble connecting the egr solenoid but right now I have no light .Those hose connection to my solenoid i had to just slide them on cause its so hard to reach from up under the car Ive replaced the egr valve and my solenoid. both OEM ORIGNAL PARTS CAuse for emissions I dont want to fool with that.
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 10-19-2018, 08:44 AM   #2
Default Re: No check engine paper clip sees code 26
'91-'95 SES/CEL flashed codes:
http://www.differentracing.com/tech_...dtc_chart.html
'91-'92 'shift to D2' and '93-'95 'coolant hot' flashed codes (only applies to automatic transmissions):
http://www.differentracing.com/tech_...ttc_chart.html
#26 SES/CEL:
http://www.differentracing.com/tech_...es/dtc/26.html
#26 'Coolant Hot' (TCC stuck on): http://www.differentracing.com/tech_...es/ttc/26.html
Paper Clip Diagnosing Pokerking1993 S-Series Tech 6 03-19-2013 01:43 PM
My check engine video using paper clip method grunthaner S-Series Tech 2 09-09-2010 03:42 PM
paper clip codes bbmuzicboi S-Series Tech 3 01-31-2008 07:10 AM
How to tell if an EGR solenoid is faulty using the paper clip 92[SL2] S-Series Tech 10 05-23-2007 10:37 PM
Paper Clip Trick on 99 SL1 SL1ByDayZByNite S-Series General 1 06-18-2006 08:10 PM
