Old 10-18-2018, 10:58 PM   #1
ElysRealm
ElysRealm is on a distinguished road
Default What fluid am I leaking?
I think it's oil. Maybe? Pictures are attached. The leak seems to be near the driverside (front) and you can also see in the first picture the bit of plastic there that is wet. It's a 99' SL1 and has about ~130k on it.
Add to ElysRealm's Reputation
Rate the quality of this post and help ElysRealm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ElysRealm is offline   Reply With Quote
Old 10-18-2018, 11:21 PM   #2
Waiex191
Waiex191's Avatar
Default Re: What fluid am I leaking?
Finding a leak is a bit of an art but not a super hard one.
1) Clean off all the oil
2) Run it a bit
3) Look for new oil
Get the big leaks first, medium second, small last.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-18-2018, 11:57 PM   #3
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
You can be more certain of what kind of fluid that you are leaking by laying down some aluminum foil under your car where the current leaks are and weighing down the corners of the aluminum foil with some rocks or nuts or something. If a drop of the liquid falls on the aluminum foil overnight, then you can more clearly see the color of the liquid. If the liquid is orange, then it's Dex Cool coolant. The transmission cooler lines can leak at the metal crimps by being pushed open by the internal pressure of steam. On my replacement transmission cooler lines, I put hose clamps on the metal crimps. If the liquid looks like oil on the aluminum foil, then it's probably oil.
Add to edlee's Reputation
Rate the quality of this post and help edlee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edlee is offline   Reply With Quote
Old 10-21-2018, 10:13 PM   #4
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
Until you find the source of the leak keep an eye on all fluids, especially brake fluid. These S Series are all at least 16 years old, brake lines don't last forever. Brake fluid is the forgotten fluid and a small drip can lead to a snapped line and a big leak and then no brakes, the last thing you want. The front passenger side brake line passes along the back of the firewall. I'd check the brake fluid daily.
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 10-29-2018, 07:43 PM   #5
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
My old trick is to rip off a piece of cardboard from a box and place it underneath. Easier to see what color it is that way. Best of luck and keep us posted!
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
Add to jpags729's Reputation
Rate the quality of this post and help jpags729 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpags729 is offline   Reply With Quote
Old 10-31-2018, 12:47 PM   #6
Saturn Night
Checking the fluid levels can be pretty concise, on which fluid is leaking.
Symptoms of which fluids are leaking:
Power Steering: Whining from pump while turning steering wheel, difficulty when steering
Transmission: Won't go into gear, slams into gear, goes into "limp" mode, sets transmission codes
Engine Oil: You will HEAR this one, as soon as the "replace engine" light begins flickering, in bright red, on the right side of your tachometer. And it will be your number 3 connecting rod blowing out the side of your engine block.
Brake Fluid: Soft brake pedal, brake pedal going to the floor, very little stopping power, vibration in pedal, illumination of the "Brake" warning light.
Coolant: High temp gauge, overheating, steam from under the hood, smell of coolant while driving, hissing and fluid boiling out as soon as you shut the engine off when it is warm.
Old 10-31-2018, 02:39 PM   #7
onlinebiker
I once rode my Sportster to work in December - so I brought it inside the shop so it wouldn't be ice cold when I went to start it on the way home after work.
I noticed later in the day a rather large puddle of oil underneath.
Harleys - especially older ones are sort of known for leaking. ( it was a 1961).
But I had built the engine and had put all new seals asnd gaskets. I knew it didn't leak.
I theorized, then confirmed it was somebody being a smartass.
I confronted the wiseguy - and told him not to pour oil under my bike. He denied it. I accused him again - and said I knew he did it...
How?
It was clean oil. The oil in the bike had miles on it.
If you' re going to mess with somebody - use dirty oil.
:P
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Leaking Fluid 01SL1SATURN S-Series General 4 02-03-2011 11:15 AM
L-200 Leaking Fluid Broke_Student L-Series Tech 6 12-03-2007 01:09 PM
SC1 leaking fluid adamsaulnier S-Series Tech 11 01-29-2007 11:09 PM
Leaking red fluid schultp S-Series Tech 2 01-26-2005 01:32 AM
Leaking Transmission fluid zmann S-Series Tech 9 01-15-2004 07:51 PM
