Old 10-18-2018, 07:11 AM   #1
54packman
54packman will become famous soon enough
1998 SW2
2000 SC2
Default Engine swap
Quick question, can a single cam engine be replaced with a twin cam engine without changing the PCM, I just spun a bearing in the bottom end in a single cam sc1, and know where there is a good twin cam motor... or do I have to switch heads over?
54packman is offline   Reply With Quote
Old 10-18-2018, 08:12 AM   #2
Default Re: Engine swap
If you never go above about 75% throttle it'll be fine, otherwise the SOHC PCM's idea of full throttle fueling will go lean on the DOHC and burn up valves.
Depending on year swapping the PCM is a 'bolt-in' affair and unless prices have changed they're pretty cheap (under $70).
Old 10-18-2018, 08:44 AM   #3
54packman
1998 SW2
2000 SC2
ok thanks, I can see if I can also find a pcm for the twin cam motor as well too
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 09:44 AM
Engine cradle swap; tranny swap MikeNW S-Series General 6 03-11-2015 01:04 AM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
engine swap ? 99 sl2 swap in 98sl2 jiffypop S-Series Tech 1 12-11-2010 11:14 AM
Engine Swap or trannie swap SL-2er Miscellaneous Tech 1 04-28-2003 05:00 PM
