Old 10-18-2018, 01:15 AM   #1
tecky11
tecky11 is on a distinguished road
Default emergency engine swap
ok., i know im going to be called a fool but that is ok, the engine in out 06 ion decided it didnt want to live any longer. it s a 2.2 with a single coil pack,(if that helps). we have a totlaed ion (2007 with coil on plug) that has everything( motor/trans/wiring/pedal) wil this motor bolt in to the 2006. BOTH are auto.
2003 saturn vue 3.0 v6
1973 International 345 v8 auto
2007 saturn Ion 2.2/auto donor car
Add to tecky11's Reputation
Rate the quality of this post and help tecky11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tecky11 is offline   Reply With Quote
Old 10-18-2018, 02:39 AM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: emergency engine swap
It will bolt in, but it is not compatible as-is because the 2007 Ion 2.2L uses some different engine management components.
You would need to install the crankshaft, cylinder head, and throttlebody from the 2006 engine in order for it to work. The 2007 Ion uses a different crankshaft position sensor and a camshaft position sensor that your 2006 doesn't have.
2007 Ion 2 Quad Coupe 5-speed manual 181K miles
2007 Chevy Equinox LT 193K miles
2018 Chrysler Pacifica Touring L 36K miles
Add to ruley73's Reputation
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 09:44 AM
Engine cradle swap; tranny swap MikeNW S-Series General 6 03-11-2015 01:04 AM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
engine swap ? 99 sl2 swap in 98sl2 jiffypop S-Series Tech 1 12-11-2010 11:14 AM
starting engine for the first time emergency!! adhhaahok S-Series Tech 11 11-27-2005 09:31 PM
