Old 10-16-2018, 07:38 PM   #1
Catch-TwentyTwo
Catch-TwentyTwo is a jewel in the roughCatch-TwentyTwo is a jewel in the roughCatch-TwentyTwo is a jewel in the rough
Default Adding LED lights?
I want to add led light strip to the trunk, could I tap the power from the 3rd brake light in the window?
Also I would like to add more lights, for this I would need a (3 place??) rocker switch
Light #1 on //// OFF //// Light on #2
so both lights cannot be turn on at the same time.
How do I figure the size of wire and where to tap as they should only be used while the car is on.....
Thank you !
Add to Catch-TwentyTwo's Reputation
Rate the quality of this post and help Catch-TwentyTwo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Catch-TwentyTwo is offline   Reply With Quote
Old 10-18-2018, 12:14 AM   #2
Sh1tb0xHero
Sh1tb0xHero is on a distinguished road
1999 SW1
Default Re: Adding LED lights?
Here is a great site for finding a wire harness with the correct gauge wiring. Also comes with the relay already attached!
This is what I used before the Spod Source.
1999 Saturn Sw1 2" lifted 170,000 miles - Daily Driver/Project Car
Add to Sh1tb0xHero's Reputation
Rate the quality of this post and help Sh1tb0xHero reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sh1tb0xHero is offline   Reply With Quote
Old 10-18-2018, 08:24 AM   #3
18-14 awg wire would be fine for nearly any average cost automotive light. I'd go with 16g wire for off-road style lights as long as it's a quality wire that measures the gauge of the copper wire and not the gauge of the cable (by this I mean cheap wire usually measures the protective outer layer as well to boost their wire size, so 16g cheap wire is actually 20g or 22g).
High power LED lights only need 2-3 amps, so even 18awg wire would be plenty for a pair, lower power strips would be fine with tiny 22awg wire.
This site has a handy chart for AWG -> Amp capacity, which is good/safe up to about 10ft of wire (plenty for the S-Series). Other charts take into account the increase in resistance and volt-droppage over long distances (20ft -> 1000ft) and recommend larger gauge wire for smaller loads. There's nothing wrong with using a larger gauge wire, they just add to the project cost and could be harder to route through the car.
https://www.powerstream.com/Wire_Size.htm
Old 10-18-2018, 09:37 AM   #4
Sh1tb0xHero
1999 SW1
So for some reason links don't work.
You could use this and hack-engineer a 3 switch rocker panel.
https://www.superbrightleds.com/cat/wire-harness-relay/
Old 10-26-2018, 04:34 PM   #5
Catch-TwentyTwo
I got the led strip lights.
5M 3528 SMD White LED Strip
• LED type: SMD 3528
• Length: 16.4FT (5M)
• LED Quantity: 300LEDs (60LED/M)
• Color: Cool White (6000-6500K)
• Beam angle: 120 degrees
• Input voltage: 12V DC
• Working Temperature: -20°to 50°
• Protection Rate: IP65 Waterproof
Adding Fog Lights to 2nd gen SL Saturninin S-Series General 5 08-16-2012 12:08 PM
Adding map lights bitterlemons S-Series Mods 21 04-24-2011 11:18 AM
adding led fog lights marx404 Astra General 22 10-15-2009 10:32 PM
adding fog lights ionracer30 Ion General 1 01-15-2006 02:47 AM
Adding Fog Lights... agood S-Series General 1 05-14-2004 03:14 PM
