Old 10-16-2018, 05:21 PM   #1
silverslp
silverslp is on a distinguished road
2002 SC1
Default Block Heater Bolt
I just purchased a used OEM block heater for my 2002 SC but it did not come with a mounting bolt. Does anyone have the size/thread for this bolt so I can pick one up at the local hardware store?
2002 Saturn SC1 - 175k Miles - Manual Trans.
2005 Saturn Ion 3 - 115k Miles - Auto Trans.
1998 Saturn SL2 - 185k Miles - Auto Trans.
Add to silverslp's Reputation
Rate the quality of this post and help silverslp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverslp is offline   Reply With Quote
Old 10-17-2018, 10:21 AM   #2
macbox
macbox will become famous soon enough
macbox's Avatar
Default Re: Block Heater Bolt
Just took a look at my block, an 8mm 1.25 goes in, and the bolt hole is a good 30mm deep. An 8mm 1.25 20 or 25mm should work. The length of the bolt is probably for transferring the heat into the block, so I would try the 25 or 30mm length bolt.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 10-17-2018, 03:06 PM   #3
silverslp
2002 SC1
Excellent, thank you!
Old 10-18-2018, 12:16 PM   #4
W1PIT
W1PIT will become famous soon enough
2001 SL2
The bolt that came with my yet to be installed block heater is 20mm long,same diameter and pitch as above.This was N.O.S purchased long ago . This maybe the year!
Add to W1PIT's Reputation
Rate the quality of this post and help W1PIT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
W1PIT is offline   Reply With Quote
Block heater 83trekker S-Series General 31 01-19-2012 12:41 AM
Block heater for a 95 SL1 Maine2Alberta Support Forum for Canadian Saturn Owners 2 12-09-2011 02:16 AM
Block Heater... D.Isaak Ion Tech 1 06-28-2011 08:17 AM
08 VUE block heater zhybridtoast 2008 Vue 3 10-31-2010 09:47 PM
Block Heater Help Growser S-Series Tech 14 12-20-2008 01:44 PM
