Old 10-15-2018, 03:41 PM   #1
onlinebiker
onlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of light
Default 98 to 99 swap
I'm going to look at another 99 SC2 tomorrow - that has a lunched auto transmission.
I have a good transmission in a 98 SC2 parts car.
That a direct swap? Looked at the swap guide, and still not sure....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 10-16-2018, 02:57 PM   #2
onlinebiker
Default Re: 98 to 99 swap
Anybody?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 10-16-2018, 03:10 PM   #3
Was hoping someone else would jump in (I have no experience). But it should be a straight swap.
You can keep the '99 auto PCM but that will keep the SES light on full time, with transmission codes. One person mentioned they could feel slight dips in power roughly where an auto trans would be shifting, but then it would pick right back up
Or you can move the PCM over with the trans, just check the options between the two cars.
Transmissions didn't really change much throughout the S series life cycle. Some gearing changes is all I can think of
Old 10-16-2018, 04:48 PM   #4
onlinebiker
Thanks ALOC...
It' s nice going into a project knowing there critical stuff....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 10-16-2018, 04:55 PM   #5
You're welcome! I'm sure you have already seen this
http://www.differentracing.com/tech_...anny_swap.html
Oh, and that reminds me, there is a few different things you do with the plugs depending on if you are using the auto or manual pcm
http://www.saturnfans.com/forums/sho...d.php?t=153772
Old 10-17-2018, 12:46 AM   #6
If they both are automatic and the same DOHC or SOHC transmission than it should be a direct no-issue swap. Going from MP7 to MP6 or MP6 to MP7 won't work at all; going from auto->manual requires a PCM swap for it to be totally happy (most report no issues other than CEL; others have my luck and get a slight hesitation when the PCM cuts timing to shift).
Old 10-17-2018, 06:32 AM   #7
Waiex191
Waiex191's Avatar
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-17-2018, 09:10 AM   #8
onlinebiker
That was 2 hours of driving wasted.
While texting the seller I asked if the underbody was solid, and he said yes.
I suppose - it wasn' t liquid.
But it did have rust thru.
I suspect he knew - as my SO watched his face when I pulled the inspection mirror out of our trunk, walked over to his car - and checked forward of the driver's side rear wheel - and immediately found rust thru at the trailing arm mount. She said his face fell....
So 10 seconds into my inspection - I said " I'll pass".
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 10-17-2018, 09:16 AM   #9
onlinebiker
Our 92 SC2 needs a new engine ( top end ) but the body is exceedingly clean. Even the paint ( white) is nice. The problem is - it' s an automatic transmission.
I have all the parts - so I probably will convert it to a manual.
So thank in advance for all the good info guys.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 10-17-2018, 10:42 AM   #10
Would be awesome to see a clean '92 SC on the road again!
Old 10-17-2018, 12:44 PM   #11
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
I did the swap, took me 14 hours as a first timer without a lift. Would probably be easier to drop the whole powertrain instead of the subframe and trans like I did.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cgg17 is online now   Reply With Quote
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 09:44 AM
Can I swap 2002 DOHC SC Auto trans swap into 2000 SOHC SL? fbr S-Series Tech 3 07-17-2014 10:08 PM
What's easier: 5th Gear Swap or full Trans Swap Tatohead S-Series Tech 6 07-30-2013 12:51 PM
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 05:45 PM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
