Old 10-15-2018, 09:41 AM   #1
Thor4SL2
Thor4SL2 is on a distinguished road
Thor4SL2's Avatar
Default Evap Purge valve solenoid
The vacuum line to the Evap Purge valve solenoid on my 1995 SC-2 is broken and cracked in several places. I want to replace it w/ a flexible vac line but can't see where it goes and none of the service manuals I have give a clear view of it. It appear to be underneath the intake manifold and above the starter.
It looks like the only way to access it is from below by removing the starter. Any body have a photo or suggestions on how to do this? Also the car is running very rough, almost stalling etc. Would the problem w/ the vac line cause this? Thanks.
It's not what you know that counts,
it's what you think of in time!
Add to Thor4SL2's Reputation
Rate the quality of this post and help Thor4SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thor4SL2 is offline   Reply With Quote
Old 10-15-2018, 10:55 AM   #2
Default Re: Evap Purge valve solenoid
Might be easier to access with the starter out, but taking that out is quite annoying by itself.
#18:
It's a vacuum line that's broken which creates a vacuum leak which makes the engine run funny/bad.
Should be able to reach it from the top once you take the intake piping out. Don't remember how it's attached, I believe some years it's got a locking mechanism while other years it just push's on/off.
Old 10-15-2018, 12:18 PM   #3
trottida
trottida's Avatar
I know this is not ideal but in a pinch I have repaired similar lines using heat shrink tubing for electrical.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
EVAP Purge Valve Solenoid LOUD Ticking 78boarder Vue General 1 01-16-2017 04:06 PM
1998 Evap Purge Solenoid majorgoals S-Series Tech 7 10-19-2014 09:15 PM
EVAP canister purge solenoid location CA-Legal-Vette S-Series Tech 3 10-19-2008 05:41 PM
EVAP purge solenoid hufhouse L-Series Tech 3 01-04-2008 11:49 PM
evap canister purge solenoid Hittman S-Series Tech 7 01-29-2004 11:06 AM
