Old 10-14-2018, 01:46 PM   #1
bigwillie1957
bigwillie1957 is on a distinguished road
2004 L-Series 3.0L Sedan
Default No start 2004 L 300
Hey anybody, our 2004 3.0 L300 with 75000 miles is a not starting. Lights are bright, with a 2 year old battery. Only odd sound is a clicking noise coming from atop the motor with the key in the run position. No RPMs when I turn it over. It does turn over strong. Has a solid lit check engine light. Checked the fuses all are good. No signs anything was gonna go wrong, just wouldn't start today.
The noise sounds like it coming from the coil pack but I could be wrong.
Any ideas?
Will
Add to bigwillie1957's Reputation
Rate the quality of this post and help bigwillie1957 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigwillie1957 is offline   Reply With Quote
Old 10-14-2018, 02:31 PM   #2
02 LW300
02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: No start 2004 L 300
Take off the oil fill cap and verify that the cam turns when someone cranks the engine. Sadly I suspect that you have broken original 14 year old timing belt.
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
Old 10-14-2018, 03:01 PM   #3
bigwillie1957
Okay I'll do that.
Old 10-14-2018, 03:21 PM   #4
pierrot
pierrot's Avatar
I'm stronly leaning in your direction here also, although I'd be happy if the belt turned out not to be broken. FWIW, on my wife's '04 Acura MDX with a 3.5L belt driven V6, Honda/Acura recommend 105K mile service interval, or 7 years by time - whichever comes first. I do believe that there is wisdom in that recommendation.
300,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 10-14-2018, 03:37 PM   #5
bigwillie1957, when you state no rpms but the engine turns over strong, do you mean no tach needle movement while starting? Can you verify the engine turning over by looking at the drive belt for movement while someone tries starting? If you see drive belt movement then the timing belt isn't broken, yet. Something else is broke.
A no tach needle movement while starting may be the only indication of a dead crank position sensor. Without an operating crank sensor the entire EFI system is dead - no fuel pump operation, no spark, no ignition for spark. The ecm cannot run with a dead crank sensor. It's next to the oil filter, mounted with one Torx bolt.
Old 10-14-2018, 05:00 PM   #6
02 LW300
02 LW300's Avatar
I hope fdryer is correct with the crank sensor, however the alternator belt will turn even with a broken timing belt.
Old 10-14-2018, 07:23 PM   #7
Rj 2000 LS2
Rj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the rough
2000 L-Series 3.0L Sedan
Fuel pump will run before the engine spins. When you turn the key, do you hear a humming noise which shuts off in a few seconds? If not, check if you have fuel on the fuel rail. Remove small cap and push the "bike tire" looking value on the fuel rail while turning the engine, or just after trying it. You should see gas spray out. If not, the fuel pump is not working check the fuse. Next would be crank position sensor, and then timing issues.
Rj
Add to Rj 2000 LS2's Reputation
Rate the quality of this post and help Rj 2000 LS2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rj 2000 LS2 is offline   Reply With Quote
Old 10-14-2018, 07:24 PM   #8
02 LW300, now that you mentioned it, you are correct - the crankshaft will still turnover since the starter turns the flywheel bolted to the crankshaft whether the timing belt is broken or not.
If the timing belt snapped, what's the chances of all 24 valves staying clear of interference to allow the crankshaft and pistons to turn without crashing and bending any valve(s)? I would guess interference engines won't not allow crankshaft rotation if either a timing chain or belt snaps.
Old 10-14-2018, 07:34 PM   #9
Rj 2000 LS2, all Saturn EFI systems runs the fuel pump for several seconds every time ignition is turned on. This is only good for checking fuel pump operation and fuel pressure. This will not help determine injector operation. Advanced troubleshooting by removing plugs to check for fuel injector operation in one way to see if injectors are working. Unfortunately, plug removal for our V6 engines are difficult since the intake runners and ignition coil pack must be removed before plugs are accessible. Other engines with easier access to plug removal can help determine if injectors are spraying, one indication of the crank sensor and ecm operating the EFI system.
Old 10-14-2018, 07:47 PM   #10
Rj 2000 LS2
I would check for fuel, if none, reset the fuel pump (maybe tripped) or check fuses. You can listen to the injectors using a short piece of PVC help against each inject while the engine is being turned over. You will hear them fire. Next, crank position sensor. My wife's went out while driving. We had it towed home and I found the sensor was bad. It's an easy fix. If the timing belt is broken, nothing would happen. If the belt jumped teeth, it might start but run really rough. Damage can occur. Timing belt is not fun to replace.
Rj
Old 10-14-2018, 08:00 PM   #11
02 LW300
02 LW300's Avatar
I purchased a very nice 2001 L300 with about 110,000 miles on it a couple years ago. The original timing belt had broken and the engine has many bent valves. Unfortunately the starter has no problem spinning the crankshaft and bending valves in both styles of engines. I do have a good 2001 v-6 out of one car and a good transmission out of another. Now I just need to find a nice L300 with a broken belt near me.
Old 10-14-2018, 08:47 PM   #12
^ That's one perfect example of a damaged engine turning over freely after valves were bent. My guess is the timing belt snapped first then the engine continued from mechanical momentum as the interference part of valves meeting pistons occurred in short order to damage the engine. If done while driving at mid to high rpm, more damage? At low speed, low rpm, maybe a few bent valves as the engine stopped? Then unknowingly cranked over to do more damage? Best guess while speculating on a damaged engine is either a tear down by removing cylinder heads or taking a chance on running a compression test. Short of removing cylinder heads or compression testing would be removing the timing cover to see if the timing belt snapped and lying in pieces.
I'll bet on a long shot that this engine wasn't run ragged with high rpm shifts, burnouts, autocrossing, track racing, lack of oil maintenance, and other things to force premature wear and tear that might contribute to timing belt damage.
Old 10-14-2018, 08:52 PM   #13
Rj 2000 LS2, there is no reset for the fuel pump. Either the pump runs or not. Fuel spraying out the fuel test valve is a great indication of fuel pump, pump relay, pump fuse and ecm operating the fuel pump. This does not say the ecm is operating injectors as the crank sensor is needed during starting/running to allow the ecm to operate all three circuits - fuel pump, ignition system for spark and injectors.
Old 10-15-2018, 12:11 AM   #14
02 LW300
02 LW300's Avatar
Timing belts usually fail on startup. They strip the teeth off at the crank sprocket and bend all the valves that are open where the cams stopped. I have been a mechanic all my life and have seen it all.
Old 10-15-2018, 12:17 PM   #15
bigwillie1957
No tach movement. I have to wait til wed. to get to the car. I sure appreciate this info. I'll know a lot more then. Crossing my fingers on this one.
Old 10-15-2018, 12:25 PM   #16
bigwillie1957
Rj
Right, I should have thought of that [cycling the fuel pump]. Thanks I'm
grateful to you all!
Old 10-15-2018, 12:30 PM   #17
bigwillie1957
Lol, Good bet, its my 60 year old wife's car.
Old 10-15-2018, 12:34 PM   #18
bigwillie1957
Rj
Thank you, I have a stethoscope. Good info for now and the future!
Old 10-15-2018, 03:36 PM   #19
Rj 2000 LS2
Good to know Saturn's don't have a Reset Fuel Shut Off Switch (Inertia Switch). - Thanks
Old 10-20-2018, 09:56 AM   #20
bigwillie1957
Update: I did the things suggested by everyone, Its getting fuel, camshaft was turning over, fuses all fine. I put my stethoscope on the top of the motor to pinpoint the clicking sound and once I touched the fuel rail I was on to something. With the key in the run position I unplugged the throttle position sensor and the noise stopped. Then the car started and with it running I plugged it back in and it ran for about a minute then missed badly and stalled. If the crank position sensor was bad would it have started? what Ive read a bad throttle position sensor will only make it hard to start and run bad, hesitate and suck gas. Used a scanner that would only give me a code with the TPS unplugged, then it spit out 7 different ones and none was crank position sensor. Could it be the computer? I'll probably start with the TPS cause its the cheapest. Thanks for reading.
Will
2004 Vue 3.5L Won't Start AHidell Vue Tech 6 12-01-2014 06:44 PM
Won't start 2004 ion nickpratt2010 Ion Tech 8 09-04-2013 05:04 PM
2004 Vue 2.2L won't start mjvandine Vue General 3 03-26-2013 12:35 PM
2004 Ion-3 Won't Start truck1985 Ion Tech 26 01-12-2013 09:00 AM
2004 Ion 3 won't start truck1985 Ion General 2 01-30-2012 12:55 PM
