Old 10-11-2018, 05:22 PM   #1
Channeler1
Channeler1 has a spectacular aura aboutChanneler1 has a spectacular aura aboutChanneler1 has a spectacular aura about
Wrench 2005 Saturn Vue Base Front Sub-Frame Bolt Removal?
Hello All!
So toiled away on my timing chain and cylinder head replacement, Only to drive it for a week and then have my Clutch slave cylinder go! UGHHHHH
So bought a new one and trying to get the Trans out (5-Spd Manual)
And the Two Front Sub-frame bolts just spin!?!?!?!
Seems weird to me that such an important part would not be protected from the elements better?
Any experience with removing these parts????
Any suggestions for how to move forward ?
Do i just cut them off and try to remove ?
New bolts from the Stealership i'm guessing?
Any help would be Golden! ~ Thanks
Add to Channeler1's Reputation
Rate the quality of this post and help Channeler1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Channeler1 is offline   Reply With Quote
Old 10-11-2018, 06:49 PM   #2
waiter21
2003 VUE 2.2L
Default Re: 2005 Saturn Vue Base Front Sub-Frame Bolt Removal?
There is a small square shaped opening on the frame that you can see the nut-plate. Use a small die grinder or sawzall and cut the opening a little wider so you can get a wrench in there and hold the nut plate.
Spray some PB Blaster in there on the threads
Add to waiter21's Reputation
Old 10-12-2018, 10:32 AM   #3
Bruce Rock
2000 SL2
2006 VUE 2.2L
I have had some success on other vehicles removing screws from captive nuts that turn by keeping tension on the screw head. Forcing a chisel between the head of the bolt and frame. The captive nut than catches on the tang or broken weld originally used to secure the nut.
You may have to treat the removal like you were tapping it. Clockwise-counterclockwise plenty of oil.
Chase the threads on nut and bolt and repeat the tension on the screw head when assembling.
Add to Bruce Rock's Reputation
Rate the quality of this post and help Bruce Rock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-14-2018, 02:28 PM   #4
Channeler1
Thanks guys
What a PITA!
OK I'll try this
Old 10-14-2018, 05:47 PM   #5
waiter21
2003 VUE 2.2L
When you drop the cradle, inspect it very carefully for rust.. Mine was completely rusted out. Scroll down to post 9 for a couple photos..
http://www.saturnfans.com/forums/sho...d.php?t=234668
These things rust from the inside out, so wack it with a hammer in the suspet areas...
Old 10-14-2018, 06:23 PM   #6
Vue6
Vue6's Avatar
2006 VUE Red Line
...AS WAS MENTIONED ABOVE A WRENCH, PB BLASTER , SOAK IT , THEN SOAK IT AGAIN, AND AN IMPACT IS YOUR FRIEND HERE, DON'T FORGET TO PICK UP A COUPLE OF NEW CRADLE BOLTS ALSO, YOU WILL NEED THEM, THE BOLTS START GETTING CORRODED IN THE CENTER, HOPE THAT HELPS, DC.
Add to Vue6's Reputation
2005 Saturn Vue Base 2.2L Won't start after Timing Chain/Head Replacement! Channeler1 Vue Tech 7 09-17-2018 03:16 PM
Crankshaft Front Main Bolt Removal jasenpeters S-Series Tech 4 10-06-2016 09:17 AM
2005 Saturn Vue Broken Suspension Bolt sp1957 Vue General 2 09-21-2012 10:51 AM
1999 saturn sl2 broken bolt in frame tbear483 S-Series Tech 2 06-28-2011 06:16 AM
1995 Saturn SL2 - Leaking brake fluid off the frame behind the right front whee DWVANDY S-Series Tech 3 02-04-2009 01:54 PM
