Old 10-10-2018, 07:33 PM   #1
Al10453
Al10453 is on a distinguished road
Default BCM change over
I had my '01 LW200 BCM replaced about 10 yrs. ago & it's failing again. I attempted to swap it out with my original one. The original one was intermittent lights etc. When I reinstalled the original one I no longer had a brake light & hatch light staying on, but the security light was on & the car wouldn't start. Does that mean it has to be reprogrammed? If the BCM hasn't failed further wouldn't the VIN that's programmed into it still work?
Add to Al10453's Reputation
Rate the quality of this post and help Al10453 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Al10453 is offline   Reply With Quote
Old 10-10-2018, 08:04 PM   #2
pierrot
pierrot's Avatar
Default Re: BCM change over
The system's security, PASSLOCK, doesn't recognize this BCM hence the security warning light illumination and a vehicle which won't start. A 30 minute re-learn procedure is required and has been written of many times in this sub-forum. See post #4 in the link below.
http://www.saturnfans.com/forums/sho...d.php?t=129705
Swapping BCMs is not particularly difficult. Remember the this particular computer (the BCM is its own computer) is also your Odometer and that memory information remains in the BCM. It cannot be altered by anyone - period. If retaining current mileage is of no interest then you need go no further than the PASSLOCK re-learn procedure. FYI, in order to maintain current mileage information one must purchase a new, or nowadays a factory remanufactured unit which is then programmed by a dealer mechanic. The odometer mileage is transferred from the old unit to the new/remanufactured/blank BCM.
307,000 miles - Holy canolli!
Add to pierrot's Reputation
How Critical to change oil when change indicator light comes on alrich Ion Tech 15 11-24-2009 04:58 PM
Can you change you change the key chime noise to the one that is in chevy and other g SaturnIONSLVUE Ion Tech 1 09-14-2009 11:28 PM
?'s about serpentine belt change and fuel filter change on '94 SL2 demontrace S-Series Tech 8 07-03-2008 03:48 PM
Need some quick help (PCV change, belt change, + advice) makenzie71 S-Series Tech 10 01-31-2008 01:05 PM
Suvery: Oil Change - By Oil Change Light or Mileage? usa4624 L-Series General 48 03-20-2004 06:17 PM
