Old 10-10-2018, 05:05 PM   #1
quickster
quickster is on a distinguished road
Default replacing engine mounts
Replaced engine mounts several years ago, but the vibrations came back after a couple of weeks.Going to replace them again and have a couple questions. Is there a certain sequence I should replace them in? Should the car be on the ground, not on jack-stands when the final adjustment on the passenger dogbone bracket is made, or is it ok to do it while it's on the jack-stands? Just need your advice in hopes that the car will be vibration-free a lot longer than last time.Thanks for any help
2002 SL2, Bought new in October of 2001, Now has 281,300 miles
Add to quickster's Reputation
Rate the quality of this post and help quickster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quickster is offline   Reply With Quote
Old 10-10-2018, 08:54 PM   #2
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
Default Re: replacing engine mounts
there is a sequence and the dog bone on the passenger side needs to be done last. I can't remember the sequence but it is important to do it correctly. The sequence is on this site someplace as I used it before, it also has the torque spec to tighten all the nuts and bolts.I don't remember using jack stands. I will say there is a big difference in the quality of the aftermarket parts, many times the one on the top of the engine is the only one that needs to be replaced as it has most of the weight on it.
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Replacing mounts SaberD S-Series Tech 7 10-01-2015 11:16 AM
Chasing down vibrations after replacing engine & trans mounts HankHill S-Series Tech 1 01-27-2014 02:43 PM
Replacing Engine/Trans.Mounts quickster S-Series Tech 64 06-01-2008 09:10 PM
Replacing all engine mounts FredM S-Series Tech 24 01-08-2008 01:23 PM
replacing all the mounts! angelaw S-Series Tech 14 07-23-2007 08:01 AM
