Old 10-09-2018, 06:44 PM   #1
pjrobbins
pjrobbins is on a distinguished road
pjrobbins's Avatar
Default P2176 code after fueling.
I have a 2003 Vue V6 and recently it started throwing this code shortly after fueling. The engine performance does not seem to be affected. I can clear this code and it does not come back until the next fuel up. A check of other posts on this code does not show any link to fueling or opening gas cap.
Anybody have some ideas?
Add to pjrobbins's Reputation
Rate the quality of this post and help pjrobbins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pjrobbins is offline   Reply With Quote
Old 10-09-2018, 09:14 PM   #2
Default Re: P2176 code after fueling.
It may be coincidence to have this error code turn up right after refueling. The error code is related to the drive by wire system - electric throttle, electronic pedal and engine computer.
Was the throttle body ever cleaned?
The engine control module (ECM) controls the throttle blades by applying a varying voltage to the throttle valve motor. The ECM monitors the actual throttle blade position using throttle position (TP) sensor 1 and 2. If the ECM cannot detect the minimum throttle position, DTC P2176 sets.
p2176 Throttle not learned pocomenomosso Vue General 11 09-15-2018 07:36 PM
Codes: P2176, 0121, 0221, 2135 rccook16 Vue Tech 6 03-20-2018 10:34 PM
Limp mode with code P2176 Casey223 Vue Tech 17 11-29-2017 01:58 PM
New View - P2176 and P0700 codes Raysp30 Vue Tech 5 09-18-2011 04:52 PM
P2176 and P1779 Z13VUE Vue Tech 6 04-26-2008 11:46 AM
