Old 10-09-2018, 04:09 PM   #1
Hackettbr1
Hackettbr1 has a spectacular aura aboutHackettbr1 has a spectacular aura aboutHackettbr1 has a spectacular aura about
Default Thing in front of temperature gauge?
no idea what this is, all it says on it is towards user with an arrow pointing towards a slit in the front of it. it sticks out of the side of the gauge cluster interior, by the glass
Add to Hackettbr1's Reputation
Rate the quality of this post and help Hackettbr1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hackettbr1 is offline   Reply With Quote
Old 10-09-2018, 08:03 PM   #2
explorerbigjon
explorerbigjon will become famous soon enough
2008 AURA XE
Default Re: Thing in front of temperature gauge?
Appears to be a microphone for a handsfree set, aftermarket equipment more than likely.
2008 Saturn Aura XE 3.5-Sport tuning T10 wheels-Dynomax bullet/Borla ProXS-eBay intake-Pioneer Premier 12 shallow mount/Kicker CXA600.1
Upgrades coming!
Add to explorerbigjon's Reputation
Rate the quality of this post and help explorerbigjon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
explorerbigjon is offline   Reply With Quote
Old 10-10-2018, 02:18 AM   #3
Hackettbr1
wish i knew how to use it, seeing how there's no bluetooth on the 08 models.
so does anyone, by chance, know what model its from?
Old 10-11-2018, 01:37 PM   #4
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
What is written next to the arrow? Hard to make it out in the pic.
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-11-2018, 01:58 PM   #5
That little thingy is obviously not a factory item and one way to find out where it goes is either pull out the instrument cluster to trace where this device connects to or feel under the instrument panel for this wire and follow it to wherever it goes. If you find the other end not connected to anything then removing or cutting it off will declutter things.
Old 10-13-2018, 01:08 AM   #6
Hackettbr1
towards user
V
Old 10-13-2018, 12:04 PM   #7
imaddicted2u
2008 AURA XE
Originally Posted by Hackettbr1 View Post
Towards user
V
Darn, was hoping it was a number that might give a clue to manufacturer.
If there isn't another set of buttons to control the hands free system, either it was removed or a GM LAN interface was used that allows the steering wheel controls to run the hands free.
If you remove the kick panel under the instrument panel I think you'll find 1 or 2 boxes depending on the setup. One may be a GM LAN interface. The other should be the Hands free interface itself that the mic plugs in to. If you can get the model numbers and post them I might be able to find the instructions.
I also found these GM instructions to pair, didn't work for mine since I don't have Bluetooth. Worth a try...
https://assets.cobaltnitra.com/teams...146edef087.pdf
Temperature gauge at 1/4...... Caferacernoc S-Series Tech 6 12-07-2015 08:55 PM
2001 SC2 issues - Gas mileage, temperature gauge, and RPM gauge. HawkeyeCB S-Series General 12 01-30-2014 12:39 PM
Resistance vs Temperature chart for gen1 gauge temperature sender? PlasticCarsRock S-Series Tech 9 11-06-2011 06:53 PM
00 SL2 Temperature Gauge zulaya S-Series Tech 5 09-06-2010 07:31 AM
Temperature Gauge wat96sl1a Miscellaneous Tech 4 02-25-2000 10:13 AM
