Old 10-06-2018, 12:12 AM   #1
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Default Intermittent Front speakers
I'm trying to help my grandmother out with the speakers in her car. Both speakers in the front cut out a lot. Most of the time they don't work at all but when they do work they sound fine. So I don't think they're blown, maybe a bad wire? I was gonna just swap the speakers in the rear to the front to test if it was a bad wire but based on what I've read, the front speakers are 6.5 and the rears are 6X9. So swapping them probably wont work. (Plus they seem like a pain to get out.) Has this problem happened to anyone else? Or does anyone know of a better way to test whats wrong?
Thank you
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-06-2018, 11:53 PM   #2
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
Default Re: Intermittent Front speakers
Since the speakers are intermittent it may be caused by corroded connector plugs. I had a blown speaker, replaced both front and later had the intermittent speaker issue, cleaned up the connections and they've been working fine since.
http://www.saturnfans.com/forums/sho...4&postcount=34
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-10-2018, 12:39 PM   #3
Brak
Brak has a spectacular aura aboutBrak has a spectacular aura aboutBrak has a spectacular aura about
Brak's Avatar
2009 AURA XE
2007 VUE 2.2L
If you are going to the trouble of removing the doors, you may consider replacing the speakers. These are are an inexpensive option. https://www.amazon.com/Pioneer-TSA16...ype=automotive
Note: It is great you are helping your grandmother out!!
2009 Aura XE Auto 2.4L Jewel Red. 87k miles
1975 Triumph Spitfire 1500
Add to Brak's Reputation
Rate the quality of this post and help Brak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brak is offline   Reply With Quote
Old 10-10-2018, 02:15 PM   #4
Zeebins
Zeebins's Avatar
Is there a guide somewhere on how to remove the doors? I've noticed Aura doesn't seem to be as well documented on YouTube as the S-series
Also, from what I read don't you need to cut some plastic to install new speakers into the door? Or maybe that was for the a pillar tweeters?
Old 10-11-2018, 01:08 PM   #5
imaddicted2u
2008 AURA XE
Door panel removal...Most Malibu/G6 procedures are interchangeable with Aura.
https://www.youtube.com/watch?v=oxZNVAPfPPU
Pretty much the way I cut the plastic for my speakers...You'll need to customize it for your particular speaker. I soldered the original speaker plug to the new speaker so it still plugged in. Make sure to clean the connections and use some dielectric grease to prevent future corrosion. I didn't and had to go back in later to do it.
https://www.youtube.com/watch?v=ltR9tZnnSO4
Old 12-16-2018, 08:56 PM   #6
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2009 AURA XR
2005 ION-3 Sedan
mine are intermittent too, which in my case means they rarely put out volume. And i've seen other posts on this here, so I can't help but wonder if there was some faulty wiring harness or something that got used on these.
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Help with front speakers Saturnsince93 Aura General 4 05-23-2013 11:44 AM
Intermittent pop from front end......... ? huntn machine S-Series Tech 3 04-21-2008 09:41 PM
Front Speakers in 99 SW2 axslinger S-Series Tech 0 06-03-2007 08:58 PM
Front Speakers 2001L300 L-Series General 14 07-19-2006 11:31 PM
03 VUE Front Speakers code0 Vue General 3 07-15-2006 01:53 PM
