Old 09-24-2018, 01:43 AM   #1
Dw89
Dw89 is on a distinguished road
Default Jack points
I need to do an oil change but I'm too big to fit under the car. I do have a 3.5 ton jack though, and was wondering if someone could point me to the jack points so I can lift this sucker up and change the darn oil!
Add to Dw89's Reputation
Rate the quality of this post and help Dw89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dw89 is offline   Reply With Quote
Old 09-24-2018, 02:04 AM   #2
1996SW2
1996SW2 is on a distinguished road
1996SW2's Avatar
Default Re: Jack points
There's a sticky thread called new or returning Saturn owners in the S Series General forum. Scan the Richpin videos on how to change oil through the wheel well.
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 09-24-2018, 05:09 AM   #3
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Block the tires.
Put a piece of 2 x 4 on top of the jack.
Slide jack and wood under the passenger front suspension, from the front.
There is a flat spot there, the 2 x 4 keeps you from scratching or bending it.
Jack car up...
PUT A JACK STAND BEHIND THE FRONT WHEEL!
There is a crimp point that shows you where to put the jack stand...
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 09-24-2018, 06:48 AM   #4
Waiex191
Waiex191's Avatar
Ramps are awesome. If mine ever rust out I'd get a pair of these. $40 minus 20% for a total of $32.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 09-24-2018, 10:16 AM   #5
http://www.saturnfans.com/forums/sho...53&postcount=6
I always use the frame behind the front subframe to jack the car up to get to the drain bolt, and get the oil filter through the wheel well.
Think about getting a fumoto (?) drain valve every so often, but have a hard time cracking the wallet open
Old 09-24-2018, 10:16 AM   #6
Officially these:
In-case Photobucket is still blocking images for some: http://www.saturnfans.com/forums/sho...9&postcount=11
Old 09-24-2018, 10:20 AM   #7
Macgyver
All good spots above. The only other one I've used that's not outlined in the photo is putting the jack on the subframe itself. Always use wood in between the jack pad and frame.
Add to Macgyver's Reputation
jack and stand points? mjoekingz28 S-Series General 8 08-06-2011 12:12 PM
Where are jack points and where to put stands darnell89 S-Series Tech 3 12-16-2007 12:37 AM
Jack points on a 2005 ion rjfox Ion Tech 2 09-29-2007 10:49 AM
Jack points ken b. S-Series General 8 06-04-2006 09:58 PM
SC2 jack points? abkaiser S-Series Tech 4 11-02-2000 07:39 PM
