Old 09-23-2018, 06:23 PM   #1
Chaz9496
Chaz9496 is a jewel in the roughChaz9496 is a jewel in the roughChaz9496 is a jewel in the rough
2001 L-Series 2.2L Sedan
2003 L-Series 2.2L Sedan
Default Right Side Drive Axle Seal.
I had to replace my flex plate for the 2nd time since April. Anyway, I have a axle seal leaking on that RT. side. I looked inside the old seal and there was a round spring around the axle stub shaft that wasn't attached to anything. The new seal doesn't have anything like that with it. I see on YouTube this isn't going to be an easy job to do. Where did this round spring come from and where does it go ? I've never done this and figure it's going to cost me quite a bit of cash if I have to have a shop do it. The YT video didn't have any thing like this when removed. Thanks in advance.
Add to Chaz9496's Reputation
Rate the quality of this post and help Chaz9496 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-23-2018, 06:52 PM   #2
Default Re: Right Side Drive Axle Seal.
Google cv axle seal images. You're likely to see many. Descriptions may explain a double seal with a garter spring. The spring you found is probably from the damaged seal losing its inner seal and may be the reason for seeing it.
Old 09-23-2018, 07:27 PM   #3
pierrot
pierrot's Avatar
fdryer's remark about a garter spring from the old axle shaft seal seems likely to me. It is difficult to tell from the pictures of the seals from RockAuto.com whether or not those springs are present. Considering that your new part doesn't have any spring around the inner lip of the seal it's possible that the seal was redesigned at some point in time.
304,000 miles - Holy canolli!
Add to pierrot's Reputation
Drivers side axle seal replacement csuengr L-Series Tech 7 08-25-2015 11:44 AM
Driver Side Drive Axle Seal Replacement acman S-Series Tech 3 12-18-2012 12:10 AM
Driver's side differential axle seal... mdevour S-Series Tech 3 10-17-2011 08:23 PM
Drive Axle...Which Side? Mozez1975 S-Series Tech 6 07-13-2011 09:15 AM
Axle seal LH side PITA Michigander2005 S-Series Tech 3 05-13-2008 06:01 PM
