Old 09-22-2018, 06:33 PM   #1
kh55343
kh55343 is on a distinguished road
Dizzy pulsating dash lights and radio
I have a 2004 Saturn ion, The dash light and radio screen all pulsate, when i put the emergency brake on it all stops. I have a new battery alternator is good i have checked battery cables i did a little test and unplugged the wire to the e-brake and it made the pulsating blinking of the dash lights worse. are these some how tied together by a ground someplace?
Add to kh55343's Reputation
Rate the quality of this post and help kh55343 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kh55343 is offline   Reply With Quote
Old 09-23-2018, 01:03 AM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: pulsating dash lights and radio
Did you install a new radio lately? If so, you probably got a couple wires crossed.
The e-brake is affecting this because DRL (and automatic headlamps if equipped) is disabled when the e-brake is engaged. This is relevant because a short circuit is being created when the e-brake is disengaged.
2007 Ion 2 Quad Coupe 5-speed manual 181K miles
2007 Chevy Equinox LT 192K miles
2018 Chrysler Pacifica Touring L 31K miles
Add to ruley73's Reputation
Old 09-23-2018, 06:31 PM   #3
kh55343
no new radio, all the rapid flashing stops when the light for the brake comes on.
Old 09-23-2018, 09:41 PM   #4
ruley73
ruley73's Avatar
Does your car have automatic headlights?
If so, does it still occur if the headlights or park lights are manually switched on while the e-brake is still engaged?
Old 09-23-2018, 10:18 PM   #5
ruley73
ruley73's Avatar
Too late to edit previous post....
You could have a bad dimmer switch or a bad connection at the dimmer switch. You can pull the pocket straight out to access the back of the dimmer switch.
Unplug the dimmer switch and see if the pulsing stops while it is disconnected. The dimmer switch does not directly control the lights. It just tells the BCM what you have it set to. The BCM then outputs the appropriate voltage to the instrument panel lights.
When unplugging the dimmer switch with the headlights or park lights switched on (automatically or manually), the odometer and radio display will go completely dim. After a few seconds they will revert back to full brightness along with all the other instrument panel lighting and remain at full brightness until the dimmer is plugged back in.
Old 10-03-2018, 07:25 PM   #6
kh55343
ok The flashing stops when the headlights come on. i am a woman and do not know where the dimmer or the panel is, i googled where the BCM is well i googled to see first what is was. anyway what do i check first i can't afford to bring this to a shop. thank you for this help.
Old 10-03-2018, 08:06 PM   #7
These drawings may help although they're drawn with the switch and binnacle(?) its attached to already pulled out, showing the rear part. Ion owners should be able to give you pinpoint directions for dimmer switch location. Click over each thumbnail to open a new page for a full screen display of each image. The dimmer switch is either a round knob or thumbnail dial. Sometimes this variable voltage device wears and becomes sensitive to road shocks, giving the impression of something wrong with the electrical the system when its just a worn variable switch. If worn and interior lighting flickers, sometimes the mere touch brightens or dims panel lighting. If this occurs, try manually dialing/turning the dial/knob in both directions several times. This may correct the flickering.
Old 10-03-2018, 08:44 PM   #8
ruley73
ruley73's Avatar
The dimmer switch is the thin, horizontal knob just below the pocket on the left side of the dash. That pocket pulls straight out with little effort. Once you remove the pocket , you'll see the back of the dimmer switch. You will need a small flat blade screwdriver to raise the locking tab which will then allow you to disconnect the plug from the dimmer switch.
96 Saturn SC2 no turn signal lights no dash lights crank over and radio walk need hel maka84 S-Series Tech 0 09-28-2016 02:49 PM
Help! Dash lights & radio out physics Vue General 10 09-19-2015 07:08 PM
Dash lights pulsating mwayne5 S-Series Tech 4 03-28-2011 09:45 PM
2006 Vue AWD Radio Lights and Dash Lights Problem molinee Vue Tech 4 04-11-2008 05:56 PM
