Old 09-20-2018, 09:29 PM   #1
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Default Blackstone Labs oil report
A few months ago I found out about this company that tells you the condition of your engine based on an oil sample. Last oil change I sent one in to see how mine is and I though some others here would be interested in looking at it. Things seem pretty good for my little Saturn, was happy to see that
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-20-2018, 09:58 PM   #2
Default Re: Blackstone Labs oil report
To make this exercise meaningful you need to pull a sample from every used oil change until you have a trend line. That is usually a minimum of 3 samples using the same brand and weight of oil and filter. The only wear sources for iron are the rings and liners. For identical change interval mileage the iron should be the same/similar as the previous sample results.
UOA 101 - Blackstone Labs BobbyP Vue Tech 0 01-20-2012 01:33 AM
Ion 2.4L A/C report Tethys Ion General 5 04-14-2006 08:38 PM
The Blackstone Report is in...Mobil 1 0w-20 David Harleyson Vue General 14 02-28-2005 12:09 AM
Engine Oil Analysis by Blackstone Labs PowerByBrower S-Series Tech 12 04-15-2004 02:09 AM
Car Fax Report? Mac S-Series General 4 01-03-2004 12:38 PM
