Old 09-16-2018, 06:57 PM   #1
Channeler1
Channeler1 has a spectacular aura aboutChanneler1 has a spectacular aura aboutChanneler1 has a spectacular aura about
Wrench 2005 Saturn Vue Oil Ring Burning Suggestions.?
Hey Guys!
Just finished a complete Head and timing chain replacement after a timing chain failure left my Vue a mess!
Got it all back together and running finally (Thanks to help here!),
Now i'm back to my original problem. LOL
I have a very high mileage Saturn Vue (240,000) ~ Was running pretty much original everything except Alternator before the timing chain went.
In my top end overhaul I replaced the Cylinder Head, Timing Chains and guides, Water pump and thermostat, Head gasket and all top end gaskets. So top end mechanical is great now.
And i'm sure some will ask "well if you did all that why didn't you just do the piston oil rings too!" lol ~ I live in a condo and pulling the Engine here to do the piston rings was impractical to say the least, got a lot of evil eyes just being out there doing the head work! LoL I Had planned to do piston rings this summer but the timing chain and cylinder head took precedence.
I Plan to schedule downtime next spring and have it at a friends where i can pull the engine and do the piston rings.
My questions is what are the best options for reducing oil burning in these engines so i can get through the winter ? Any recommended products?
I'm burning 2+ quarts of oil a month easy with my high miles work commute and it sucks!
Any Suggestions or Ideas would be Welcome!
Thanks !
Add to Channeler1's Reputation
Rate the quality of this post and help Channeler1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Channeler1 is offline   Reply With Quote
Old 09-17-2018, 07:22 AM   #2
atikovi
Default Re: 2005 Saturn Vue Oil Ring Burning Suggestions.?
That's what? $5 or $6 a month? $60 or $70 a year? I wouldn't bother doing anything. With the money you save not doing oil changes, it's nearly a wash.
Add to atikovi's Reputation
Old 09-17-2018, 10:55 AM   #3
If you can get compression numbers, you might find which cylinders is low, presuming the lower compression is the oil user. Maybe try one quart of thicker oil? Instead of refilling with whatever you're topping off with, maybe one quart of 40 weight oil may help. Higher viscosity oil is thicker and may help reduce oil consumption but you'll have to monitor the engine as we're going into winter cold temps. You don't want 100% high viscosity oil to turn into jello with slow engine cranking in freezing weather. If the initial quart of 40w oil doesn't help, go back to whatever you're using.
Suspension and other suggestions for higher mileage 2005 3.5 Vue Rockstarvue Vue Tech 8 05-06-2016 06:13 PM
ecm tuning 2005 vue v6 ja35a3 http://www.drivewire.com/vehicle/2005-saturn-vue/ecu-up teamsheetz Vue General 2 10-28-2012 04:33 PM
Saturn Aims to Ring in a New Era Charlie General Saturn Discussion 3 03-29-2009 12:40 PM
Why isn't there a Saturn Ring? Admiral Beez General Saturn Discussion 5 02-21-2006 01:00 AM
This Outer Ring Red Saturn 94sc2boy Mods and Performance 3 04-07-2003 11:23 AM
