Old 09-14-2018, 12:28 AM   #1
Aaronj863
Aaronj863 is on a distinguished road
Dizzy overhead consoles?
does anyone know of any overhead console that have the temp sensor in the overhead unit instead of under the hood im looking to put a suburan overhead console or explorer console in my 98 sl2 and want the temp gauge but dont want to have to pull the sensor with the console and have to wire it up, or maybe a universal compass/temp reader that will fit in its place and look factory?
Add to Aaronj863's Reputation
Rate the quality of this post and help Aaronj863 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Aaronj863 is offline   Reply With Quote
Old 09-14-2018, 07:59 AM   #2
toggenburg
toggenburg's Avatar
Default Re: overhead consoles?
Welcome to the Forum.
Am I reading you correctly, engine temp, not ambient temp?
Overhead console from Suburban's don't have engine temp displays that I am aware of. Sure, like many cars these days, the rear view mirror displays outside ambient temperature, but where have you seen what you want?
I've owned 5 suburbans, and currently have 2 but none had what you want as a option.
Old 09-14-2018, 08:25 AM   #3
You can't get outside air temp with a inside sensor...what good is a inside temp sensor when it's not controlling the HVAC?
You can take a rearview mirror from '99-'02 Silverado (and I assume similar trucks) to get Temp/Compass/Auto-Dim in the rearview, just need to borrow power/ground from the cabin light wires. The compass and auto-dim work fine with just power/ground hooked up, the temp sensor needs to be wired to have it display something more useful than OC (Open Connection).
Old 09-14-2018, 08:30 AM   #4
trottida
trottida's Avatar
Everyone I've seen has the ambient temp sensor just behind the grill at the front. It shouldn't be hard to pull and you can run new wire to save time pulling it. If I recall correctly it's not that complicated.
As far a Suburbans go, I've owned a 2001, 2005 and currently a 2011. In the 2 GMT830s (1999-2006) the display was in the rear view mirror and in the GMT930s (2007-2014) they are in the gauge cluster. In the current Suburban platform I understand it is integrated into the central stack radio display. I prefer the mirror if I had a choice but the centre stack would probably be good too.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 09-16-2018, 09:07 PM   #5
Aaronj863
that what i mean is the temp sensor thats under the hood behind the grille not inside the car lol i read this wiring guide for a explorer ohc install in a bronco just tapping into power and wiring the sensor and all worked even had the wire color coding to what they are.
Old 09-20-2018, 07:08 PM   #6
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
Check this out for Consoles
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Add to Saturninin's Reputation
Rate the quality of this post and help Saturninin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturninin is offline   Reply With Quote
FS: Homelink Overhead Consoles jimmyfloyd Aura General 5 10-05-2015 10:35 PM
05 Quad coupe consoles z16monte Ion Tech 4 01-12-2013 05:36 PM
Center Consoles MKD S-Series General 16 05-20-2005 07:29 AM
Armrests/Center Consoles for S-Series jambra1 S-Series General 0 02-11-2005 04:09 PM
HELP! Floor Consoles for the L thatjerryguy L-Series General 0 03-08-2004 01:27 PM
