Old 09-13-2018, 11:47 AM   #1
natedawg1604
natedawg1604 is on a distinguished road
Default Passenger Side CV axle C-clip
Hi there,
So, I recently replaced (among many other things) the passenger side CV Axle on my 96 SL2. For some reason it seemed impossible to get the new CV Axle past the c-clip, it seems like the C-clip was a bit deformed and prevented the new CV axle from being properly seated. Because I was very short and time and needed to get to work the next morning, I pulled the c-clip out and am currently driving without it (I know, I need to put it back in).
In a few days I'll be in a position to spend some time getting the CV axle re-inserted correctly, but I need some suggestions on what to do. For example, should I go to a junk yard and try to find another C-clip in better condition? Is it possible to buy a new C-clip at an autoparts store or online? Any suggestions would be greatly appreciated...
Add to natedawg1604's Reputation
Rate the quality of this post and help natedawg1604 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
natedawg1604 is offline   Reply With Quote
Old 09-13-2018, 12:40 PM   #2
RobertGary1
Default Re: Passenger Side CV axle C-clip
I believe this is GM 07829495 which isn't available any longer. I've not seen anyone sell them without the axle. J/y may be a good option but honestly I'd probably just try to drive it in. I've had some that are very difficult.
The Axle is very strong in compression. If you push the axle into compression you can tap it (not slam it) with something heavy (I used a sledge hammer) to push it past the ring. Its not worse then hitting a big rock in the road.
-Robert
Old 09-13-2018, 01:25 PM   #3
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Many (most...all?) aftermarket axles have c clips that are too large. Swap the clip from your old axle over to the new axle and it should pop right in.
Cheers!
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 09-13-2018, 01:55 PM   #4
natedawg1604
Cheers!
So, my new axle (passenger side) didn't come with a C-clip. I currently only have the original clip that was in the Rack & pinion bar. Is it possible to buy another CV axle that DOES come with a usable c-clip?
Old 09-13-2018, 02:47 PM   #5
colonelhogan44
Oh, interesting.
McMaster has them.
https://www.mcmaster.com/c-clips
In California, McMaster standard shipping shows up the next morning. YMMV depending on location.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 09-13-2018, 03:07 PM   #6
natedawg1604
Oh, interesting.
McMaster has them.
Wow, interesting. Does anyone know what size I would need to order?
Old 09-13-2018, 03:39 PM   #7
colonelhogan44
That I do not know. I have a couple spares, but they are at a different location so I can't measure before you'll need to know. Measure the old one and post up the dimensions and we can help you choose the right one.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 09-13-2018, 05:03 PM   #8
After removal and before install always gently compress the ring into its grove, do this multiple times around the ring. The OEM is not a plain C clip it is a formed ring.
Old 09-13-2018, 05:07 PM   #9
floridasl22002
I saw this You Tube and thought it may be useful to you with the C clip issue....
https://www.youtube.com/watch?v=oeKJ-YUMHAY
Old 09-14-2018, 09:40 AM   #10
natedawg1604
It seems like one end of the ring is protruding slightly beyond the groove; is that normal, or should the ring be totally flush to the groove?
Old 09-14-2018, 10:02 AM   #11
colonelhogan44
It should have some play in the groove, IIRC. An OEM axle with a ring in good shape should pop in without a lot of force. The video posted by Floridasls2002 shows the rings being available at the auto parts store. You might want to get a new one to make sure you can get the axle in this time since this is your primary transportation.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 09-14-2018, 11:02 AM   #12
natedawg1604
It should have some play in the groove, IIRC. An OEM axle with a ring in good shape should pop in without a lot of force...
Okay, let's back up. Should the new axle INCLUDE a new ring? Because the one I got from Napa did not. At this point I have no problem buying a new CV axle, I just need a link to the proper website or store...
Old 09-14-2018, 11:44 AM   #13
colonelhogan44
All of the axles I have ever bought aftermarket had rings included. Last year I helped a buddy install a NAPA driver's side axle to his wife's 1999 SL2, and it had a ring. The ring was too large and prevented us from installing the axle without switching it out for the one on the original axle, however.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 09-14-2018, 11:52 AM   #14
RobertGary1
Someone probably needed a ring so they bought the axle and returned and now you got it.
-Robert
Old 09-14-2018, 01:15 PM   #15
floridasl22002
If it were me and had bought from NAPA, my first action would be to speak with the NAPA store you got it from and confirm if it should have had a clip. If the answer is yes and yours didn't and you have the receipt for the purchase, they should swap it out for a drive axle with the clip.
If it should not have come with a clip, then they should assist you with the issue. Burt my gut feeling is it should have had a clip. The whole point of buying a complete drive axle is it is plug & play.
Old 09-14-2018, 01:38 PM   #16
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
I agree with the above advice.
I have bought a few over the years and they always came with the clip.
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is offline   Reply With Quote
Old 09-16-2018, 10:34 PM   #17
natedawg1604
UPDATE: So, I went to the junkyard and got a replacement c-clip, and the CV axle went on my car with said replacement clip in about 45 seconds. I'm guessing when I took the curb hit and the CV Axle split apart (yeah, it was a nasty curb hit) the c-clip ring somehow got deformed.
HOWEVER, now I have another issue: When I turn the wheel right, at a certain point I hear a single clicking noise. It comes and goes pretty fast, it's not continuous. It sounds like it's coming approximately from the center-front area of the car. Does this sound like a rack and pinion assembly issue? About the only things I haven't replaced on my front suspension system are the inner tie rods and rack and pinion assembly...
Old 09-17-2018, 08:12 AM   #18
Clicking is usually a bad outer CV joint. The bad one is on the side you are turning into. See if the click rate changes with a slower turn speed.
Old 09-17-2018, 08:47 AM   #19
natedawg1604
How is that possible, I replaced both CV axles last week? Also on both sides of the vehicle I replaced the outer tie rods, lower control arms and struts with new parts from Napa. I also replaced the subframe and sway bar from junk yard parts.
Old 09-17-2018, 09:23 AM   #20
Mark_b
Maybe it got damage when you put the clip would not go in.
Passenger-side Axle Mount cdes Vue Tech 6 05-27-2016 01:21 PM
Passenger side cv axle change cdxhizors S-Series Tech 27 04-14-2015 06:43 AM
passenger side axle fordtruckguy Ion General 1 11-09-2011 11:03 AM
bad hub/axle passenger side. Replacement?? custardspie S-Series General 3 07-12-2009 01:44 PM
Passenger side axle... hit_n_run S-Series General 23 03-10-2008 09:39 PM
