Old 09-12-2018, 08:47 PM   #1
imaddicted2u
imaddicted2u is a jewel in the roughimaddicted2u is a jewel in the roughimaddicted2u is a jewel in the roughimaddicted2u is a jewel in the rough
2008 AURA XE
Default Oil filter adapter gasket 3.5L
A couple of weeks ago I changed the oil filter adapter gasket.
It was easy to change. I read things that said the serpentine belt and AC compressor bolts had to be loosened. I didn't have to do any of that. I'm between oil changes so I didn't drain the oil. Just spun off the filter and topped up afterwards. Took out 2 bolts, loosened the third one at the slot. Cleaned up the mating surfaces and put it back together. (disconnect the battery or the starter is live)
You can see the crack in the original gasket which allowed oil to leak around one of the bolts. The whole center fell out when I took it out.
The Fel-Pro gasket is a much better, simpler design. Part number is 72423.
I have another small leak to fix. One of the bolts that go in to the side of the oil pan is seeping a bit. The oil level is above it so at the next oil change I'll take them all out and RTV them.
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-16-2018, 08:55 PM   #2
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2009 AURA XR
2005 ION-3 Sedan
Default Re: Oil filter adapter gasket 3.5L
I'll be getting mine done on wednesday of this week.
I got the gasket from autozone, I think it's a duralast.
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Replace Oil Filter Housing Adapter/Gasket Xfinityguy Aura General 1 04-28-2018 10:39 PM
Gasket for the air filter box? Ornstein S-Series General 3 04-24-2015 10:32 AM
Oil Filter Sender Adapter TvSteve S-Series Mods 9 08-08-2008 11:12 AM
VUE oil filter adapter jbuob Vue Tech 7 01-21-2006 08:16 PM
V4 oil filter adapter--where to buy whammo18 Vue General 11 05-02-2005 07:18 PM
