Old 09-12-2018, 08:46 AM   #1
KDulcimer
KDulcimer is on a distinguished road
Default How to check if engine turns over
I'm going to go look at a Saturn tonight or tomorrow night. The seller says it's a no crank, no start. I want to make sure the engine turns over.
1. Do I need to remove the accessory belt?
2. I turn it at the harmonic balancer, right?
3. What size socket do I need?
4. Which way do I turn it?
5. Should a ratchet be enough to turn it, or should I take my 2 foot breaker bar?
SaturnFans helper map: http://bit.ly/1uDorVF
1998 SW2 & 2002 SL sold, but I still see them around!
Purchased automatic 1996 SW2 September 2018.
Add to KDulcimer's Reputation
Rate the quality of this post and help KDulcimer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KDulcimer is offline   Reply With Quote
Old 09-12-2018, 09:09 AM   #2
Default Re: How to check if engine turns over
#s 4&5, use breaker bar and extension and you have to take off the wheel and splash shields. Take a set of large sockets as that pulley bolt can be different sizes. Turn CLOCKWISE ONLY.
If it is a manual turns put in 5th gear and just push it forward. If it moves the engine turned over. DO NOT PUT THE KEY IN THE ON POSITION AS IT MAY ACTUALLY START! Just put key in OFF position.
Old 09-12-2018, 12:04 PM   #3
00_SL1
00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough
00_SL1's Avatar
2001 SL2
Post #15 in the sticky thread
New or Returning S-Series owners' checklist Version 3.0
01 SL2
04 Silverado
06 Uplander
05 Express
Add to 00_SL1's Reputation
Rate the quality of this post and help 00_SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
00_SL1 is offline   Reply With Quote
Old 09-12-2018, 03:49 PM   #4
Pulley bolt head will vary as mentioned, but mine was 21mm
Never tried it for pushing the car, but I imagine pulling the plugs will make it easier to push.
Definitely easier to turn with plugs out, if using a breaker bar at the crankshaft pulley
Failed Smog Check After Erasing Check Engine Light Code trench619 Ion General 9 05-01-2015 11:58 AM
Check Engine light turns on then off lndstatic Astra Tech 2 10-29-2013 08:47 PM
94 SL2 engine turns but won't run nelsonind S-Series Tech 18 11-23-2009 06:53 PM
Check engine light turns off when gas tank full dennis_houston S-Series General 2 02-09-2008 11:41 PM
Engine fan only turns on when AC is on ? Frank91 L-Series General 2 06-29-2007 01:16 PM
