Old 09-11-2018, 03:51 PM   #1
jpsuli
jpsuli is on a distinguished road
jpsuli's Avatar
Default Dash Panel Switch Re-Wire to battery?
In an effort to get a factory fog light feel, I have the switch and fog light housing themselves. I see there was a way to wire it up via the fuse box but I wanted to know if there is a way to rewire the switch pictured below to the battery via a relay as I want to replace the left empty button with another item as well as my fog lights. Also I already have a wire ready on a relay in the engine bay already...
I couldn't find a diagram via google for the connector that connects to this switch.
'97 Saturn SL2 @ 139k
Breakin' stuff as we go.
Add to jpsuli's Reputation
Rate the quality of this post and help jpsuli reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpsuli is offline   Reply With Quote
Old 09-11-2018, 09:01 PM   #2
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Default Re: Dash Panel Switch Re-Wire to battery?
The wiring from the switch to the UHJB (Under-Hood Junction Box) is still there, you just need to wire from the UHJB to the fog lights. All you really need is the lights, some good wiring, a few connectors for the lights, and a couple spare UHJB pins to mate together. My brother and I both installed fog lights on Saturns, his a 1997 and my dads a 1999. The 1999 had the relay already, but the 1997 did not.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-12-2018, 07:53 AM   #3
trottida
trottida's Avatar
Wire it like factory; it's not that difficult and it is well documented. Don't let the fuse box connections scare you; it's not as complicated as one would think.
When I did it I used the factory fog light harness on the donor car but clipped the section out that was difficult to access and replaced it with a new wire (soldered and shrink wrapped). It would be easy enough to build your own harness.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 09-27-2018, 12:39 AM   #4
jpsuli
jpsuli's Avatar
Did it
How easy is it to add a wire to the underhood fuse panel? IT_Architect Vue Tech 6 10-10-2016 04:20 PM
How can I run a wire between the dash pad and windshield? IT_Architect Vue General 0 12-29-2015 09:12 AM
How do I connect a wire to the battery? Evankeirce S-Series General 3 05-24-2012 12:00 AM
Loose Fuse Panel Wire - What to do? suic1d3 S-Series Tech 5 05-15-2012 12:54 PM
Space between dash pad and front dash panel jsevinsk S-Series Tech 4 08-09-2011 02:33 PM
