Old 08-26-2018, 09:26 PM   #1
dbtoth
dbtoth is on a distinguished road
Default Low engine performance?
Hello, I have a 2008 Saturn Astra XR 2 door with about 110,000 km on it. The car started acting up one night on a drive home from work. Check engine light came on and it diagnosed as multiple misfire and I got the ignition coil pack, spark plugs and engine air filter replaced. Shortly after the check engine light started coming on intermittently but had to leave town for work for a couple months leaving the car behind. Came back home and replaced battery (the old one was pretty worse for wear as I bought it used a couple years ago). Noticed the check engine light on again and took it in. So they replaced the exhaust cam sensor and the check engine light has been off ever since. However, the engine still seems to be low power. I would floor it and the car with accelerate but rather slowly. It was much more rev happy before the whole ignition coil pack fiasco. No check engine light or reduced engine power light. Car is perhaps a little louder than normal but other than that no smells, lights or other indicators. Any ideas?
Add to dbtoth's Reputation
Rate the quality of this post and help dbtoth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbtoth is offline   Reply With Quote
Old 08-27-2018, 11:54 AM   #2
JFS
JFS has a spectacular aura aboutJFS has a spectacular aura aboutJFS has a spectacular aura about
JFS's Avatar
2008 Astra XR
Default Re: Low engine performance?
Do you have any codes to share?
Add to JFS's Reputation
Rate the quality of this post and help JFS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JFS is offline   Reply With Quote
Old 08-27-2018, 08:00 PM   #3
NJastra
NJastra is on a distinguished road
NJastra's Avatar
2008 Astra XR
When this happened to me, it was the cam position sensor that triggered the engine light and resulted in low performance.
-Jon-
3 dr XR, Twilight Blue, 5 speed manual, 18" 5-star rims, Leather trim package, Heated seats, VXMMI (Advanced Audio)
2017 Regal GS, 20", fully loaded
1987 Z28 - modded
Add to NJastra's Reputation
Rate the quality of this post and help NJastra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NJastra is offline   Reply With Quote
Old 08-28-2018, 10:59 PM   #4
kikastra
kikastra has a spectacular aura aboutkikastra has a spectacular aura aboutkikastra has a spectacular aura about
kikastra's Avatar
2009 Astra XR
Same with me. I forget the code numbers, but this is a common problem with these cars.
2009 Saturn Astra XR3 5-Speed - 77,000KM
Add to kikastra's Reputation
Rate the quality of this post and help kikastra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kikastra is offline   Reply With Quote
Old 08-29-2018, 12:37 PM   #5
dbtoth
I just scanned the computer and no codes are coming back. I'd hate to take it into a garage and have them tinker around with it and try to figure out what the issue is. Would be an expensive and time consuming endevor.
With all of the components that were replaced and the fact there are no codes, I'm at a bit of a loss.
Old 09-14-2018, 02:35 PM   #6
NJastra
NJastra's Avatar
2008 Astra XR
I know that you replaced the coil pack, but I wonder if there's a chance that it might be faulty? When I had a sensor go bad one time, the lack of performance appeared random or at least not regular. Eventually the engine light came on. Maybe in time it will trip a code and light? But it can be dangerous to drive around and not have power when you absolutely need it. Flipping the A/C on must feel even worse, it already is a strain on a well-functioning motor (hey maybe the extra strain will make the motor be like, ok dude, enough...here's your damn light lol). If I remember correctly, my light came on both times under acceleration when it was lagging.
-Jon-
1987 Z28 - modded
Old 09-15-2018, 01:00 AM   #7
nicolas_p
nicolas_p has a spectacular aura aboutnicolas_p has a spectacular aura about
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
I had the same issue a couple years ago, No CEL but poor performance. I tracked it down to a cracked cam position sensor, $100 part and about 2 minutes to replace in your driveway.
There's also a little screen on the cam position sensors that can get clogged up giving you poor performance with no CEL
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Eibach Sportline, Whiteline BHR75Z swaybar and EBC Rotors
CD30 Mp3, Insignia jets, vxR surround, sharkfin antenna, Spoiler, Tint
Add to nicolas_p's Reputation
Rate the quality of this post and help nicolas_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nicolas_p is offline   Reply With Quote
Old 09-15-2018, 05:22 PM   #8
AstraFasta
I have run into low engine performance several times on my Astra. These maintenance items all helped me boost performance at different times:
1. Double check gap on all your spark plugs.
2. Do you have proper spark plugs (there are a few recommended here and by GM). Wrong temp or gap could cause drivability issues.
3. Possible bad coil pack as a few people here got cheap ones that had issues right away. OEM is lower risk, higher cost.
4. The two camshaft solenoids (intake & exhaust) each have 2 (?) orange filters. Many of us removed them. I think there was a GM service note on that.
5. If engine oil is old, get that and filter changed. The cams perform poorly with old oil.
6. Run a few tanks of ultra-premium gasoline from one of the majors (like Exxon or Shell). They have very expensive detergents to clean.
7. Look for vacuum leaks (make sure air filter box was properly closed when you recently changed air filter).
8. Clean MAF (only use MAF cleaner and don't touch wires!).
9. Clean throttle body. There are instructions here so you don't lose a finger or knock off calibration.
10. The noisy engine & low power could be a bad flex joint or catalytic converter. The flex joint is a frequent item to fail in salty environments (like Canada I suppose). Typical replacement is just to cut out small section and weld in generic part (the GM part is expensive and may be difficult to get). A dead cat would be more expensive but less common; when really acting up should throw a code.
Add to AstraFasta's Reputation
Rate the quality of this post and help AstraFasta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-30-2018, 08:26 PM   #9
Astra08
Astra08 is on a distinguished road
Astra08's Avatar
2008 Astra XR
Along with reseating and checking your gas cap if you're not seeing any codes with the CEL..yes, I know it sounds weird.
Add to Astra08's Reputation
Rate the quality of this post and help Astra08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra08 is offline   Reply With Quote
Old 12-01-2018, 05:20 AM   #10
rsneha
rsneha is on a distinguished road
Same here
Add to rsneha's Reputation
Rate the quality of this post and help rsneha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rsneha is offline   Reply With Quote
Old engine had super performance. new engine doesn't fixityourselfer S-Series Tech 12 08-28-2014 12:39 PM
performance engine 00strawredsl2 S-Series Mods 1 10-28-2012 12:38 AM
Engine performance issues- 96 SC2 raind0wn388 S-Series Tech 9 01-18-2011 12:43 PM
Engine performance for VUE Disworld Mods and Performance 2 11-25-2004 02:10 PM
VUE engine performance mods? Hobbes Vue General 19 09-29-2003 01:20 AM
