Old 08-21-2018, 11:14 AM   #1
lionfish37
lionfish37 has a spectacular aura aboutlionfish37 has a spectacular aura aboutlionfish37 has a spectacular aura about
Default Headlights Chime no longer working
I have had my saturn for about 10 years. The fusebox had to have work and is working but I no longer have the chimes for my headlights and keep leaving them on.
Anyone have a fix for this? The fusebox inside has been repaired a few times and its just old... Worn out. LOL
Add to lionfish37's Reputation
Rate the quality of this post and help lionfish37 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lionfish37 is offline   Reply With Quote
Old 08-21-2018, 11:52 AM   #2
ErikTande
ErikTande will become famous soon enough
ErikTande's Avatar
Default Re: Headlights Chime no longer working
Try replace the daytime running lights fuse. That controls the leaving the headlights on chime.
I know because when I did this mod, the chime stops working.
https://www.youtube.com/watch?v=i2J6otMcWzA
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 08-21-2018, 02:14 PM   #3
lionfish37
So by doing this mod you got your chime back? My problem is I keep leaving the headlights on and since no chime come out to a dead battery.
Old 08-21-2018, 02:30 PM   #4
ErikTande
ErikTande's Avatar
No, you LOSE the chime if you do this mod. So try replacing that fuse, it might fix your problem.
Old 08-21-2018, 10:29 PM   #5
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
I know it’s stupid- but. Is your door ajar switch working?
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 08-22-2018, 11:46 AM   #6
lionfish37
Door Ajar, I need to check thank you
Old 08-27-2018, 10:34 PM   #7
TomM96
Dunno what year car Lionfish is navigating, but...
As the door hinges Wear, the door's aft section (which communicates with the Door Ajar switch) moves vertically in addition to swing fore-and-aft, hence eventually destroying the switch mechanism. Those switches are also subject to corrosive degradation of the contacts....
Later model years Moved the switch location from aft (down low) to forward/high (side of instrument panel) where the relative movement dictated by the angular swing fore/aft, is Minimized, and up-down is limited as well.
Add to TomM96's Reputation
Old 08-28-2018, 03:36 AM   #8
jhonky
jhonky is on a distinguished road
Completely rewire your f5 curcuit. 🤣
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
RKE no longer working trouttrooper S-Series Tech 0 10-09-2014 01:43 AM
95 SLII Back-up lights no longer working Kaveman S-Series General 7 01-03-2013 12:45 PM
Chime device not working cblawton L-Series General 11 07-02-2010 09:38 PM
Cruise control no longer working SL1Guy S-Series Tech 3 10-01-2009 08:21 PM
Lights on/ keys in ign. chime not working LotusLord Vue Tech 0 07-15-2008 11:03 PM
