Old 08-19-2018, 08:45 PM   #1
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
Default Best door jamb switch 1997 SW2
My battery went dead last night because I left my headlights on due to my headlights on warning chime didn’t work since my door jamb switch broke. I want to find a nice new switch.
I have yet to find a new OEM part as of yet but I did find the part pictured in the bottom half of the attached image (the original working passenger side switch is pictured in the upper half).
I have yet to pull the broken switch out but wanted to purchase an adequate replacement part before hand.
Question 1): based upon your experience, is the switch pictured in the lower half indeed the correct switch?
Question2): Are the OEM switches still available?
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 08-19-2018, 09:31 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Best door jamb switch 1997 SW2
I don't know if this GM Gen 3 will work in your Gen 2. If so, someone will thumbs up or down on it.
$20 acdelco off ebay.
https://www.ebay.com/itm/fits-2000-2...8AAOSw8FBbIvF9
Can you just swap one from a rear door instead?
Then, twist the wires together, use electrical tape real good and stuff it back into the donor switches empty hole?
Otherwise, local salvage lot I'd guess.
Old 08-19-2018, 09:40 PM   #3
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
The part number for that switch is 21023335, and the only place I can find it new is on amazon for $92.66. Which seems a little expensive if you ask me. If you want to be super cheap about this you could just take the switch from the passenger door and move it in the drivers side (assuming the passenger door switch works). They're the same part.
Edit: Not sure how I missed that eBay listing. Probably because it doesn't have the part number in the title. If it is the right part though it should work. The part number says it fits 96-02
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Door Jamb Switch availability MacExperts S-Series Tech 14 05-16-2018 12:06 AM
door jamb switch- ARE YOU KIDDING ME? MikeNW S-Series General 9 01-31-2016 07:13 PM
Door jamb switch Stupidusernames Vue Tech 3 01-13-2015 10:58 AM
where is dome light switch in door jamb? ddemier7 Ion General 2 10-05-2013 01:30 PM
Door jamb switch on 1999 SC@ tmaugham S-Series General 8 03-19-2013 05:01 PM
