Old 08-18-2018, 02:03 PM   #1
Cavell
2004 VUE 3.5L
Default 06 AF33 trans
Got an 06 equinox with af33 trans. Is drain amount the same as the 02-03 vues? About 4.5 qts? I see no info online about them
Add to Cavell's Reputation
Old 08-18-2018, 02:14 PM   #2
atikovi
Default Re: 06 AF33 trans
Maybe check with the Equinox forums.
Add to atikovi's Reputation
Old 08-22-2018, 01:35 PM   #3
Cavell
2004 VUE 3.5L
it does have the yellow fill plug. all the info i have seen online shows the drain plug in a similar place. bottom of housing of course but i dont think it is exactly the same as the vue. which seems odd since it is an af33. i suppose you fill it till the dipstick says good.
my nox had very dirty internal engine parts so i am going to do a 30 day oil change in the next week or so. and paying $30 more for toyo trans fluid sorta annoys me. but i assume trans fluid has never been changed
Old 08-29-2018, 02:31 AM   #4
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
We still have the 2007 Equinox in my thread (link below) from the Chevy forum with 187K miles on it now.
https://chevroletforum.com/forum/equ...-change-46403/
I've seen conflicting information regarding the amount of fluid required for a drain & refill. The Transmission Fluid Replacement procedure for the Equinox in the FSM says 3.3 qts is necessary, but the Fluid Capacity Specifications section says 4.29 qts is necessary. The latter seems more likely, which matches the specified amount for the Vue with the same transmission.
I've done a drain and fill on our Equinox twice. The first time I got about 3.75 quarts drained out while performing the complete fluid exchange. However, about 4.25 quarts drained out the second time a few years later. I never did find out why there was such a difference. I highly recommend measuring what you drained out if at all possible because of this. You can always add a more fluid if it measures a little low afterwards, but taking a little bit of fluid out is more of a challenge.
You need to take the Equinox for a short drive before checking the fluid for an accurate dipstick reading.
2007 Ion 2 Quad Coupe 5-speed manual 179K miles
2007 Chevy Equinox LT 190K miles
Add to ruley73's Reputation
Old 10-03-2018, 09:58 PM   #5
Cavell
2004 VUE 3.5L
Got 4.1 qts out? So I put 4.5 back in. My last vue drained out 3.5 and I just figured it was low so I also put in 4.5
My nox actually seems ok. Except for the darn front end quiver on bumps. Ordered new struts but they are not here yet
Old 10-04-2018, 01:26 AM   #6
Here's a reprint for '05 Equinox with AF33-5 xmission drain and refill procedures. I don't know if xmissions changed and presume they remained the same with minor changes in electronics.
File Type: pdf Transaxle Fluid Replacement, '05 Equinox.pdf (149.7 KB, 0 views)
Af33 trans Cavell Vue General 0 02-03-2013 09:28 PM
No Voltage to IACV + Trans problems...Replace Computer or Trans Val Body or Both ialonso S-Series Tech 1 05-22-2009 04:23 PM
Overfilled trans Fluid, now TC not lockout. Is Total trans rebuild ahead? 62morgan S-Series Tech 14 02-23-2009 09:30 AM
Aisin AF23 or AF33? kevinthenerd Ion General 2 07-19-2006 01:43 PM
ATF Specification: 3 liter Vue AF33 5-Speed AndyH Vue General 2 01-06-2005 03:41 PM
