Old 08-18-2018, 09:06 AM   #1
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Default AC drain plug
Does anyone know if the ac drain plug is accessible through the wheel well
I have a 1996 SL1
Thank You
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 08-18-2018, 01:25 PM   #2
Default Re: AC drain plug
Ac drain plugs don't exist.
Old 08-18-2018, 02:23 PM   #3
hholbein
1997 SW2
If you're looking for the drain port, check out this youtube video by RichPin06a.
https://www.youtube.com/watch?v=W0VdFRDdgvA
If you have long arms, you might be able to reach it through the passenger's side wheelwell vs. getting underneath it.
Let us know what you find!
Add to hholbein's Reputation
hholbein is online now   Reply With Quote
Old 08-18-2018, 03:18 PM   #4
RobertGary1
I spent some seconds trying to parse what he was saying too and then thought maybe itís too early jn the morning for me to process.
Radiator drain plug? Block freeze plug? Evaporator drain?
-Robert
Old 08-18-2018, 04:39 PM   #5
OU812
1996 SL1
I meant the drain hole, i saw Richpins video, i still would like to know if you can get to it thru the wheel well,
Old 08-18-2018, 04:48 PM   #6
OU812, if you meant the ac condensate drain port (not a drain plug), hholbein gave you a link to a richpin video. The condensation water from the interior evaporator drains out thru a duck valve - a soft rubber valve allowing water to drain but prevent insects from crawling in. Its in the middle of the firewall, down by the four lines - two are ac, two are coolant lines for heat. The drain valve is as shown in the video. Whether you can reach it thru a wheel well depends on how long your arms are and if you can reach it. Everyone reaches it from below the engine. Can you jack the car up and use a jack stand for backup safety?
Old 08-18-2018, 04:54 PM   #7
OU812
1996 SL1
My arms are short so i will follow richpins video. Thanks
drain plug saturnsctwo S-Series Tech 1 02-19-2016 05:57 PM
Exactly where is the oil drain plug?! yankclp Ion General 4 11-21-2005 04:39 PM
Oil Drain Plug (3.5l)... 04SilverVue Vue General 24 02-10-2005 12:45 PM
Oil Drain plug cjm1719992002 Ion Tech 1 12-10-2003 09:19 PM
V6 Vue Oil Drain Plug DAC94SL2 Vue Tech 3 06-21-2002 07:12 AM
