Old 08-17-2018, 09:05 PM   #1
chrisr123
chrisr123 is on a distinguished road
1991 SL2
Default 2007 Vue Power Window - Driver's
The driver's power window isn't working. If it were any other window I wouldn't bother -- all other windows are fine. I've replaced the window switch and when that didn't fix it, I changed the window motor in the door. I can jump signal the motor and the window works, but it's not working from the switch. Any ideas? A wire short somewhere? Thanks.
Add to chrisr123's Reputation
Rate the quality of this post and help chrisr123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chrisr123 is offline   Reply With Quote
Old 08-17-2018, 10:53 PM   #2
Default Re: 2007 Vue Power Window - Driver's
Assuming you are using an outside power and ground source to see if the window motor works.
Have you used a test light to see if there is power and ground to the motor connector when the switch is operated? The power and ground will switch wires when the up or down is used. Best quick test is a test light across the motor connector. It should light up when the switch is used to go up or down.
If no power or ground I would suspect broken wires in the body to door harness.
Add to ssicarman's Reputation
Old 08-17-2018, 11:01 PM   #3
double post
Old 08-18-2018, 01:07 PM   #4
chrisr123
1991 SL2
Thanks so much. This is helpful. I think it's likely I have a shorted wire where the door is hinged to the car. Others on this site have reported that problem.
Old 08-18-2018, 02:20 PM   #5
atikovi
I would test from the connector at the switch. See if you can make the motor work by putting power and ground to the appropriate wires. If it still doesn't work, check continuity and shorts to ground between the switch connector and motor connector.
Add to atikovi's Reputation
Old 08-19-2018, 12:07 PM   #6
chrisr123
1991 SL2
Both led lights on the switch panel are working including the led for the driver's window switch. Could there still be a problem with the connector if the led lights are lit?
2007 Ion 2 driver's door window regulator MikeHarrison Ion General 3 06-04-2013 08:38 AM
2007 Ion 3 Quad Driver Window issues lilfoot81 Ion Tech 2 11-04-2011 08:14 AM
2007 ion3 driver window grinding noise germy104 Ion Tech 1 11-03-2011 09:28 AM
'96 Sl2 Driver's power window does nothing dddaaa S-Series Tech 5 08-30-2011 01:15 PM
Driver's side power window pooped out again 99SC2; other window/sunroof fine. Help? Jens99SC2 S-Series Tech 4 11-09-2005 07:40 AM
