Old 08-17-2018, 08:03 PM   #1
theroadwarrior
theroadwarrior is on a distinguished road
Default Oil pressure light after sitting in traffic
Traffic jam the day after last. Oil pressure light came on idling at stoplight, rev engine light goes off.
Replaced timing chain cover last weekend, it had cracked from not having enough studs in motor mount after rebuild.
My guess is i didn't torque down the torx screws over the pump cover correctly. I have it out and it's not loose, what worked after the rebuild was just putting Loctite on a dry screw (put it on oil soaked screws this time).
My question is the oil seal that does not have the metal ring, I can't tell what way it goes back in with the internal cone towards the engine or the cover. I have it towards the cover at the moment.
Oil pump from new cover had no noticeable gaps could not get a feeler gauge in there, primed it, the light did not come on until the traffic jam.
Add to theroadwarrior's Reputation
Rate the quality of this post and help theroadwarrior reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
theroadwarrior is offline   Reply With Quote
Old 08-18-2018, 08:40 AM   #2
Saturn Night
Default Re: Oil pressure light after sitting in traffic
I would suggest checking the oil level amd possibly connecting a mechanical gauge to the hole in the block where the oil pressure sending unit goes and verify what your oil pressure is.
You may need to order a new front seal kit, as well. Those o-rings are not to be reused, as torqueing down the timing cover actually crushes them. Mahle makes the timing cover kits.
Oil Pressure Light Orso-Grigio S-Series Tech 13 04-21-2016 09:45 AM
2003 Vue stopped running at traffic light-help cchrrice Vue Tech 7 09-09-2011 10:35 PM
SC2 Overheating While sitting in traffic Illybey S-Series Tech 9 05-08-2008 12:25 PM
Idling at traffic light ciw S-Series General 4 03-23-2005 10:29 PM
Oil Pressure Light jezebella S-Series Tech 11 02-02-2005 12:14 AM
