Old 08-17-2018, 04:09 PM   #1
sc2 saturn
sc2 saturn is on a distinguished road
Default sc2 axle seal question
i changed my axle seal driver side last night 4 hours later got it in... cause didn't realize there was a snap ring that held it in, i was curious could i person remove the snap ring and leave it out? cause the seal seems to have a tight fit into the housing and also dose passenger side have snap ring too or only driver side? i did put the snap ring back in just to make sure cause wasn't sure if i could just leave it out
its a 01 sc2
Add to sc2 saturn's Reputation
Rate the quality of this post and help sc2 saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2 saturn is offline   Reply With Quote
Old 08-17-2018, 04:41 PM   #2
toggenburg
toggenburg's Avatar
Default Re: sc2 axle seal question
It's gotta be there.
Snap rings are designed to sit in their fossa/groove and keep every thing from shifting, that snap ring ensures you don't have it all fly off as you drive.
Old 08-17-2018, 09:38 PM   #3
RobertGary1
In theory itís pretty critical. Nothing wrong with compressing the axle, holding it compressed and tapping with sledge hammer to seat.
However I have reassembled without the snap ring when I didnít have one on hand and proceeded to put over 1,000 miles on it without issue.
-Robert
Old 08-17-2018, 10:45 PM   #4
its a 01 sc2
The left side axle seal on the transmission is the only one with a snap ring on it. Not sure why they think the seal needs the snap ring to hold it in place but I would think that they felt it is needed for what ever reason. Someone had to justify the expense of having it there.
Add to ssicarman's Reputation
Replace Axle Seal While Replacing Axle? Keblar S-Series Tech 1 10-18-2012 03:35 PM
Axle seal replacement question Hjoken S-Series General 1 07-23-2012 12:51 PM
Transmission leak, axle seal question?? jackl S-Series General 4 07-23-2010 06:33 PM
Do I have the right axle seal? turbobuick33 S-Series Tech 10 07-08-2008 08:14 PM
Question about the snap ring inside the axle seal turbobuick33 S-Series Tech 11 07-05-2008 12:37 AM
