Old 08-15-2018, 06:21 PM   #1
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Default 5th Gear swap nuts
Hello all,
Im doing the 5th gear swap on my 1995 Sl2. I have secured the gear set, two spare nuts, and a new OEM gasket. The issue is the nuts. I cannot find new ones. I thought about using high temp loctite but do not want to have to heat up the nut to remove it again, for fear of trans damage. Any suggestions??
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-15-2018, 06:26 PM   #2
Waiex191
Waiex191's Avatar
Default Re: 5th Gear swap nuts
Those parts are steel. I think you will find the locktite gives up long before the transmission parts do.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 08-15-2018, 07:22 PM   #3
cgg17
cgg17's Avatar
Okay, will it harm the seals or anything?
Old 08-15-2018, 09:16 PM   #4
Waiex191
Waiex191's Avatar
Those seals are pretty far from the nut. The gasket under the cover will be replaced.
Bryan Cotton
Old 08-19-2018, 12:52 AM   #5
cgg17
cgg17's Avatar
I did the swap with the red high temp loctite, worked well, car now does 2000 rpms at 60, 2300 rpms at 70, and a whopping 3100 rpms at 90. Well worth it.
Old 08-19-2018, 09:59 AM   #6
bumpdraft
bumpdraft's Avatar
1998 SW2
If you get a chance, please let us know the before/after mpg.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 08-19-2018, 01:11 PM   #7
There have been serveral volumes written on how to recycle the nut once. Double nutting when soaked in ATF will not do much more than a single nut. A single cleaned used nut and a cleaned shaft along with 3M-TL71 has proved effective as well as just installing and torquing the nut. Search is your labor saving device. This mod was whipped up by 2 people and all pertinent info is right here on the forum.
Old 08-19-2018, 06:20 PM   #8
cgg17
cgg17's Avatar
I do not track my mpg, I am a heavy footed driver and have a broken trip odometer that I do not want to do yet. I did not double nut it, I figured that with all of the suggestions on here I would just do the loctite. I just did this for the longevity of my engine. I rarely use 5th, but will be using it daily now on my commutes to college.
Old 08-19-2018, 06:37 PM   #9
All that is required is to completely clean the shaft of remaining thread locker, it is not easy to remove, and final clean with 100% isopropyl alcohol or acetone. Same for the nut. Then use Locktite 272 or 3M TL71 thread locker and torque to spec. There is no slamming in a manual trans so they do not come loose. You can also use Locktite 620 but future removal will be a challenge.
Old 08-19-2018, 08:04 PM   #10
cgg17
cgg17's Avatar
I did clean the nuts and the shafts to remove the old threadlocker or whatever it was, I used 620 I believe. I dont plan on removing them...
Old 08-19-2018, 09:30 PM   #11
cgg17
cgg17's Avatar
Actually used Permatex 27100, I was curious so I dug it out of the trash... Good up to 300 Fahrenheit, package says it must be heated to 500 Fahrenheit to remove/ disassemble.
Old 08-19-2018, 09:45 PM   #12
The threadlocker begins to lose strength in the 200F range and is completely destroyed at 500F. Not necessary deceptive advertising but somewhat misleading. To obtain the highest thread locking requires excellent cleaning and use of the primer, when this is done then it is quite tenacious at elevated temperatures. They freely tell you this in the TDS but those are rarely read. There are graphs of the force in ft-lb required to break the bond at various temperatures. The 271 and 272 are functionally equivalent.
Old 08-20-2018, 08:01 AM   #13
cgg17
cgg17's Avatar
Do you think it will still hold for me or is it a time bomb waiting to back off?
Old 08-20-2018, 08:12 AM   #14
If this is the first recycle of the nut they work just fine. None of them have come loose as far as we know. The only known failure was a DIY incorrect reassembly where the washer that sits against the input shaft bearing was allowed to drop down and that resulted in gross excesive clearance inside of the transmission.
Old 08-22-2018, 04:44 AM   #15
Commeatus
Commeatus is on a distinguished road
1998 SW2
1997 SW2
I just finished my first 5th-swapped tank and here's what I found:
highway went up by 2-4 mpgs across the board. live data shows situations where I used to get 34, I'm now getting 37+. power between 40 and 60 mph is marginally lower, but not in any way I care about. it's not any harder to pass above 60 in 5th than it was before.
city mileage has gone down! from 25ish down to around 23. I live in seattle, very hilly, making the new 5th difficult to use below 35. the jump from 4th at 35 is from almost 2k down to about 1200! this means I'm sitting in 4th going 25 and 30 where I used to be in 5th, and the time spent in the higher 5th isn't enough to make up for it.
the ECU also really, really doesn't like dropping below 1100 rpm. it seems like it runs rich to offset the lugging, so putting down any meaningful power below ~30 mph isn't saving any fuel. the ecu also hates cutting fuel when engine braking in 5th at low rpm. I think it gets nervous
I'd say if you're in a hilly city like seattle and never do any highway, don't do the mod. if you live in a flat place or spend a lot of time on the open road, go for it!
Add to Commeatus's Reputation
Rate the quality of this post and help Commeatus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Commeatus is offline   Reply With Quote
Old 08-22-2018, 08:23 AM   #16
Generally you will find in any city that 5th gear is just no longer useful. Using the 0.654 gearset and smaller diameter tires will improve 5th gear city performance where low traffic density performance is adequate. The 0.603 gearset is an overdrive gear and not going to work below 35-37mph.
Old 08-22-2018, 09:39 AM   #17
Rolling (over 5mph) idle is about 1200rpm...of course it's not going to be happy about being forced to run lower than that. Don't think there's a workaround other than a custom PCM.
I had better mileage with a 100% stock '96 SC2 than a MP2 swapped '97 SW2. Nice, awesome reliable 3-4mpg higher with the SC2 despite running the engine at a higher RPM at 70mph. Even found out that Mobil & Shell would give me about 2mpg more than Sunnoco/Irving while Cumberland Farms docked me nearly 5mpg!
Old 08-22-2018, 11:23 AM   #18
Waiex191
Waiex191's Avatar
Thanks for the report. I think that if I ever want the benefit of the taller 5th gear, I'll make sure an SL1 is attached to it.
Bryan Cotton
Old 08-22-2018, 11:42 AM   #19
trottida
trottida's Avatar
My 99 SL2 MT gets better average mpg than my 01 SL1 MT...however it does have 150k less mileage on it and through the course of the year the SL2 probably gets more extended highway mileage. I drive the SL2 and my daughter drives the SL1. Both are mostly city runabout cars with a <10 km commute and about 14k KM per year.
In 2018 YTD the SL2 averaged 28.5 MPG(US) and the SL1 is 26.9. If I look back to 2015 when I was sole driver of the SL1 it averaged 26.1. Going back several years the SL1 has been about the same average MPG.
In my last full year driving the 93 SW2 AT it tracked 23.9 MPG. That was in 2009. That same year the SL1 tracked 24.3 over 4 months and in 2010 was at 25.7.
Looking at all the numbers, I think I've determined that for around town driving the DOHC has better fuel economy and for highway miles the SOHC is better.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
S Series MP3 5th gear swap to lower MP2 gear? Dman12ny S-Series Tech 4 07-11-2017 09:09 AM
FS: 3rd gen sohc 5th gear with New OEM gasket and nuts ddeuces22 S-Series Mods 2 09-04-2016 08:24 PM
5th gear swap, gear stack mess... mattwithcats S-Series General 2 04-23-2015 07:54 PM
What's easier: 5th Gear Swap or full Trans Swap Tatohead S-Series Tech 6 07-30-2013 12:51 PM
1st Gen 5th gear swap fullyloadedSL2 S-Series Mods 17 11-09-2012 11:43 AM
