Old 08-15-2018, 03:38 PM   #1
timl865
timl865 has a spectacular aura abouttiml865 has a spectacular aura abouttiml865 has a spectacular aura about
Default Odometer just added 500k miles!
Hi, my 02 lw200 with 192k miles all of a sudden reads 690981! Wtf? Any ideas on what would cause this?
Add to timl865's Reputation
Rate the quality of this post and help timl865 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
timl865 is offline   Reply With Quote
Old 08-15-2018, 05:47 PM   #2
bluesl2
bluesl2's Avatar
Default Re: Odometer just added 500k miles!
Get ready to have to replace your body control module. Any other weird electrical issues with the car? The mileage that is displayed on the instrument cluster comes from the body computer.
Add to bluesl2's Reputation
Old 08-15-2018, 07:11 PM   #3
Dsaturn
Dsaturn is a jewel in the roughDsaturn is a jewel in the roughDsaturn is a jewel in the roughDsaturn is a jewel in the rough
2001 L-Series 2.2L Sedan
Check for loose or dirty connection to BCM. Check all grounds to make sure they are not corroded. Also check battery for corroded or loose connections.
Add to Dsaturn's Reputation
Rate the quality of this post and help Dsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dsaturn is offline   Reply With Quote
Old 08-16-2018, 01:14 AM   #4
timl865
Ugh thanks
. Where is the bcm located on this car?
Old 08-16-2018, 01:31 AM   #5
pierrot
pierrot's Avatar
I'm in full agreement with post #s 3 and 4. If connections turn out to be otherwise okay then your options are as follows:
1) Purchase a "new" replacement which can be found at RockAuto.com, at OE websites, or from a dealership. Take the replacement BCM to a dealership's service department where the most accurate information can be programmed into the new unit. This is the only way to retain your odometer's actual mileage. Or you can...
2) visit a wrecking yard and pull one from an L-Series car or wagon of the same model year and with the same engine as yours. There's 30 minute "marrying" procedure that a DIYer can do and is written about in these forums. Once complete you're good to go except...the mileage shown will be that which is stored in the used BCM and not what your actual mileage was. If that is not of any particular consequence to you then this is the least expensive repair option available.
Avoid this altogether:
3) There are companies which claim to be able to rebuild or otherwise repair your original BCM. However, members of this forum who have attempted use them have only met with failure. No knowledgeable member here recommends using such companies.
302,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 08-16-2018, 04:57 AM   #6
Bryan4257
Bryan4257 is on a distinguished road
Me thinx electronic failure.Prolly need a new cluster, if it's important to ya
Add to Bryan4257's Reputation
Rate the quality of this post and help Bryan4257 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bryan4257 is offline   Reply With Quote
Old 08-16-2018, 01:19 PM   #7
pierrot
pierrot's Avatar
Originally Posted by timl865 View Post
Ugh thanks
The BCM sits atop the glove box case. The glove box door and case have to be removed so as to access and separate it from the case.
Old 08-19-2018, 06:09 AM   #8
timl865
Thanks guys. I dont care about the mileage if i change the bcm. I just dont want any further problems. I will try the upull next week.
Old 09-01-2018, 04:42 PM   #9
Russet
2002 L-Series 3.0L Sedan
That will require a GM TECH II and only GM dealers have them they will have to reprogram and restore the correct mileage back to the new BCM to get it working again.
Add to Russet's Reputation
2002 Odometer KM to Miles jblank288 S-Series Tech 9 03-17-2014 11:09 AM
Just turned 10K miles, added a 2.4 badge golftango Aura General 10 07-07-2010 07:44 AM
Odometer gremlin added 190K aldo S-Series Tech 0 01-29-2009 06:56 PM
What to do about extra miles added by service dept dperez Outlook General 35 11-21-2007 11:05 AM
Luke has GOTTA BE CLOSE to 500K TXSaturn02 S-Series General 18 07-08-2007 06:40 PM
