Old 08-13-2018, 11:54 PM   #1
StrnWolf
StrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura about
1994 SL1
Default Do Rear Windows Vary?
This has been driving me nuts for a while. There has been damage to my car from some sort of collision that an owner managed to almost do a perfect repair when they had it. The rear drivers side door has been replaced along with all the panels from there to rear of car including wheel area. The bumper shows signs of a repair incident, but the one thing that screams "I was hit!" Is the rear window. ALL body panels and doors and everything inside and out line up perfectly, but the window does NOT fit. On drivers side there is a big gap between where the window wraps around the side and the rear panel and also the inside of car.
It is clear a donor car was picked for the job, but my question is, do the rear windows vary by some models to where they would not fit properly like this?
What also is a mystery is the windshield seal is NOT original, it was replaced because it is not all worn. But the rear one, it is as worn as it would be from 1995.
07/2018-PRESENT 1995 SL2
04/2009-01/2019 1994 SL1
Add to StrnWolf's Reputation
Rate the quality of this post and help StrnWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StrnWolf is offline   Reply With Quote
Old 08-14-2018, 12:16 AM   #2
Default Re: Do Rear Windows Vary?
Should be identical '91-'95 4dr (wagons use the same panels/parts from the rear doors forward as the sedans minus the headliner).
Possible '96-'02 will physically fit but...it won't be happy.
Old 08-14-2018, 12:51 AM   #3
StrnWolf
1994 SL1
If they all are identical then why does it not fit right? Maybe a bad quality aftermarket?
Old 08-14-2018, 10:41 AM   #4
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Post a picture.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Do shift programs vary by year? atikovi Vue Tech 0 01-23-2018 06:21 PM
Rear windows don't go down all the way... The Critic S-Series Tech 9 11-18-2006 10:19 PM
Help? Map Sensor under vacumn - does it vary the voltage or the frequency? doddster S-Series Tech 3 11-18-2006 02:42 PM
How much should a timing chain replacement cost? Results may vary :( Tupperware S-Series Tech 26 09-19-2005 02:14 PM
rear windows ViPeR_PsY Mods and Performance 2 04-13-2002 05:53 PM
