Old 08-13-2018, 01:25 AM   #1
RobertGary1
Default Replacing front trailing control arm bushing
The FSM says you need to remove the control arm and I'd want to redo the alignment if I did that. But I've seen some imply they were able to remove the trailing bushing with the control arm in place. There doesn't seem to be much room to pull it back off the shaft but maybe some twisting and torquing would do it??????
-Robert
Old 08-13-2018, 02:11 PM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Replacing front trailing control arm bushing
...IF THIS IS THE ALUMINUM BUSHING , YOU CAN GET IT OUT BY TWISTING AND USING A PRY BAR, I DID IT ONCE TO REPLACE THEM , THEN LATER IN MY VUE'S LIFE I DECIDED TO GO WITH COMPLETE MOOG LOWER CONTROL ARMS, JUST MY .02, DC
Add to Vue6's Reputation
Old 08-13-2018, 05:39 PM   #3
RobertGary1
Thanks. I'm kind of thinking worse case if I can't get it far back enough to slide off I could remove the forward control arm bushing but keep the control arm attached to the knuckle.
-Robert
Old 09-10-2018, 06:37 AM   #4
RobertGary1
I wasn’t able to push the control arm down enough to slide the rear bushing off without removing the control arm from the cradle. However I did not need to remove it from the strut assembly.
-Robert
Old 12-13-2018, 10:10 AM   #5
redlinevue
redlinevue will become famous soon enough
redlinevue's Avatar
2004 VUE 3.5L
So.. If I'm understanding, you can get this off with some 'prying' ... my concern is then, getting the new one back on as it won't have the same amount of play... Does anyone have photos of this process by chance to help me out? Also, if I take off the bolt that sticks thru the bushing, does that increase the access for removal at all?
Add to redlinevue's Reputation
Rate the quality of this post and help redlinevue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
redlinevue is offline   Reply With Quote
Old 12-13-2018, 09:24 PM   #6
atikovi
I just replace the whole arm. If that bushing is bad, the other one and the ball joint can't be far behind.
Add to atikovi's Reputation
Old 12-14-2018, 10:17 AM   #7
redlinevue
redlinevue's Avatar
2004 VUE 3.5L
Yeah.... the others are indeed probably not far behind... just hoping to not have to also get an alignment.... this photo does help greatly though as it gives me a different angle on that bushing... looks as if once I get the two main bolts off, i could then slide it out of that support and rotate it enough to get off the arm. Has anyone else who's done this have any additional photos to share? thanks
trailing arm bushing fetchitfido S-Series Tech 1 04-05-2013 01:16 PM
trailing arm bushing 04 AWD rowdydog Vue Tech 2 11-01-2012 09:16 AM
ion3 front bushing for lower control arm nizhonigirl Ion General 2 05-05-2011 10:37 AM
Trailing arm bushing for '05 VUE Whiteline Vue Tech 1 11-02-2009 05:03 PM
Front Lower Control Arm Rear Bushing beensmoked L-Series General 1 12-17-2004 12:46 AM
